Originally Posted by 16Volt View Post
I forget, what are you running turbo wise again? Still the K27-7200?
Yup, still running the K27-7200.
Brooke
1969 911 ST 3.8 EFI ITB (Irish Green), 1973 911 RS tribute 3.3 turbo (Gulf Blue), 1974 911 3.6 (Black), Beck 904 2.8 project (Silver), 1996 993 C2 (Polar Silver)
2006 Forester STI, 1992 BMW 325 Cab S52 M3, 1952 MG TD with F20C
Old 12-13-2017, 08:48 PM
Originally Posted by TurboKraft View Post
Most excellent!
Surprising how your HP carries so well past 6,000rpm. Must be a total blast to drive!
Definitely a lot of fun to drive. Interesting that it seems to pull better beyond 6,000 rpm than normal. Not sure why that would be.
Brooke
Old 12-13-2017, 09:08 PM
Originally Posted by RarlyL8 View Post
Nice mods added to a great looking 911! Don't really understand the need for 3 boost settings though, I'd just leave it at full boost all the time and let the right foot do the modulating. My red rocket had similar specs, 360whp and 2700lb with me in it. The 915 could blow the 345mm tires in 2nd gear at will, loved it!
Maybe after driving it more and getting used to the way the boost hits on higher settings I'll feel the same way. For now, especially in the wet, I like having the options.
Brooke
Old 12-13-2017, 09:11 PM
3 restos WIP = psycho
kenikh's Avatar
Amen. In the wet, a modded 930 is scary AF.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 12-13-2017, 09:24 PM
So, with the motor fairly well dialed in, the next project is to add a second oil cooler up front in the center location to help dissipate the heat this motor generates. Currently the car has only the engine mounted cooler and the carrera style cooler in the front passenger fender. The car needs more than that, so today I picked up an EB Motorsports RS style front bumper from Rothsport Racing with opening for a center cooler. This is by far the nicest fiberglass bumper I have ever seen, being formed with both inner and outer molds so the backside is as nicely finished as the front. I expect it to fit well with very little fettling. I have an Elephant center cooler kit and chassis duct ready to go. I’ll post some updates on this as I do the work.
I should probably also note that when the motor was rebuilt, we pulled the tranny (short bell housing 930 4 speed) and inspected it. It showed as a fresh rebuild needing nothing and even had a Quaif torision torque biasing differential. That explains how the car put the power down so well.
At the same time I installed polybronze suspension bushings all around to replace the worn rubber units and confirmed the car has 21 and 27 torsion bars, and that the shocks were in good shape. It now has a very smooth and controlled ride with great transitional response.
I also upgraded to a 23mm master cylinder (with vac assist), rebuilt 993 calipers front and rear and 930 rotors all around (early two piece floating style in front with Rebel Racing center hats). The car now stops hard and has more than enough brake to match the motor.
Brooke
Old 12-13-2017, 10:32 PM
Crotchety Old Bastard
RarlyL8's Avatar
Your engine should not have a heat issue at all, the single Carrera cooler should be all you need. Is there some hard duty going on like track use or idling in traffic for an hour?
Old 12-14-2017, 04:35 AM
Well, after driving the car for a while in this state of tune, I have to agree with Rarelyl8 and say it doesn't need a second front oil cooler for street driving. So I left the early S valance on it as I prefer the looks of it to the RS bumper.
I've been doing some additional refinements on the car as well. I installed some houndstooth ST style seats, swapped out the tired old turn signal lenses for some new euro ones, cleaned and detailed the engine bay (redid a few electrical connections, refinished fan and fan housing, ext), and installed some LED projector headlights. I think this car is just about done.
Brooke
Old 08-09-2018, 08:46 AM
TurboKraft's Avatar
Brooke -- that looks fantastic, nicely done.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 08-09-2018, 11:15 AM
Been experimenting with recording video with good sound to capture the experience of driving this car. I think Iím getting close.
https://m.youtube.com/watch?v=bAmuGezGijc
Brooke
Old 09-08-2018, 11:09 PM
puddy's Avatar
Car looks great and sounds even better!
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 09-09-2018, 05:11 AM
I second that!
Old 09-09-2018, 05:13 AM
Brando
quattrorunner's Avatar
Very cool.
Turbo powa!
1977 911s. it's cool
Old 09-09-2018, 09:50 AM
I agree. I kept fairly cool even in TX heat. I did have an issue with some kind of blockage while on a drive that caused the motor to overheat. That was expensive. Get that checked out.
Old 09-10-2018, 05:15 AM
'76 911S 3.0's Avatar
Sounds excellent! Love the way the front lifts under hard acceleration!
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 09-10-2018, 12:55 PM
Here is a full video we just did.
https://www.youtube.com/watch?v=HeQv4vK-0zg
Brooke
Old 09-10-2018, 01:39 PM
flat6pilot's Avatar
Looks great, Brooke! Nice video, too.
Kyle
-Kyle
* 1980 911SC - 3.0l R.o.W 8.6:1 w/ Garrett 30R turbo conversion (.5 bar), Bitz MS-II EFI, Carerra intake, Zork tube, 2300lbs, 360whp
Old 09-13-2018, 01:31 PM
This car is now listed for sale on Bring a Trailer.
https://bringatrailer.com/listing/1981-porsche-911sc-15/
Brooke
Old 09-25-2018, 10:36 AM
Brando
wish I could buy that
Turbo powa!
Old 09-25-2018, 11:51 AM
On BAT ...oh no. Best of Luck. I think my 914-6 will end up there. Not sure if I can deal with the arm chair experts!
Old 09-27-2018, 06:35 PM
So the car previously didn't meet reserve when auctioned on BaT. It is now relisted there with no reserve. Auction ends at noon on Tuesday May 28.
https://bringatrailer.com/listing/1981-porsche-911sc-18/?utm_source=transactionalemail&utm_medium=email&utm_campaign=bat_bid_placed_seller
Brooke
Old 05-24-2019, 09:49 AM
