Help with odometer needed
Took the 930 for a run today and the odometer stopped. The speedometer still works fine, but the milaege travelled has stopped. I was wondering is it electrical or mechanical. My 930 is 1988 model, 95,000kl on the odometer. Do i need to check something electrical. If its mechanical odometer, how do i pull the speedo/ odometer out of the dash. Any help guys greatly appreciated.
There's a plastic gear that turns the odometer. It disintegrates over time and needs to be replaced. You can fix it yourself or send it out for repair. The gauge is just pressed into the dash ( the rubber grommet holds it in).
Odometer Gear replacement for Electronic Speedometers (long)
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Thanks mate. So do i just screw the cover plate of from the dash from the interior, or do i have to remove it from under the dash?
That's a good writeup.
Odometer Gear replacement for Electronic Speedometers (long) I'll be needing to do the same some day. There's also somebody on YouTube that posted a video of it. Ken, the entire gauge just pulls out from the front of the dash
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
I found it easier to pull the clock out first then push/pull the speedometer out.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD |
same here.
