Air compressor with 120psi, impact gun, and a big socket. 46mm if I remember correctly.
Old 06-01-2015, 03:58 PM
That I can do, how did the pics come out?
Old 06-01-2015, 04:33 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by turbo owner View Post
... how did the pics come out?
Both up-side down...
Are you loading from your desk top?
Who Will Live... Will See
Old 06-01-2015, 06:09 PM
iPad, I take the photos with the power button on the left side and lens in the lower right corner.
Old 06-01-2015, 06:55 PM
JJ 911SC's Avatar
I take them with iPhone/iPad, transfer them to my desk top and rotate them 360 degrees (even if they look right) and save them. I don't think the iPad let you do that, I rotate one photo 360 degrees but won't let you save it because as far as its concern you did not change anything...
The "natural" position is for the lens to be in upper position; upper left for landscape and upper right for portrait.
Old 06-02-2015, 01:54 AM
T77911S's Avatar
just buy the tools.
you will need the socket, the holder the dial gauge and gauge holder to do the cams when it goes back together,
i have a holder for the later engine that i have never used and have a 46mm crows foot for the early engines that i have used once.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 06-02-2015, 02:57 AM
Originally Posted by T77911S View Post
just buy the tools.
I did some tree work when I was still in the tree business for a gentleman who owns an import repair shop, he told me he would help if needed. I will call him when it's time to put the puzzle back together, I'm sure he has those tools.
If he won't , I'll be looking to borrow, buy or rent from someone willing.
Old 06-02-2015, 04:42 AM
46 mm is correct and it worked out perfect, on to the next stage.
Old 06-02-2015, 07:39 AM
Cleaning it up and taking it apart. All total I found 7 broken intake head studs and 2 broken rings. ARP head studs are going in, I already have those. I'm probably going to the-ring it. I have to buy two sets for sure, why not buy six. The pistons and cylinders are still useable. The heads are a big question mark that I'll be starting on next.
I'm trying to figure the picture thing out, I don't know why they are upside down. It was suggested that I try turning the iPad over so the camera lense is on top. This last set of pictures I did. How did they turn out?
Old 06-03-2015, 04:51 PM
Banned
Those pictures are oriented normally (unlike Paul, who's orientations are decidedly abnormal!).
That's really something about all of the broken studs, and looks like you are making good progress!
Old 06-03-2015, 04:57 PM
Lens to top it will be.
I sure hope Paul doesn't do a Bruce Jenner on us, I can't vision Paulina.
Old 06-03-2015, 06:50 PM
Banned
^^^ I guess that's what one would call a "not easily reversible modification", right?!?!
Old 06-03-2015, 07:20 PM
Large Member
krasuskyp's Avatar
I... I can vision Paulina.
you can?
I'm flattered!
is that a proposition???
(myfukkinGAWD are entirely too many of our available 'emoticons' here entiiiiiiiiiiirely tooooooooooo gheyyyyyyyyyyyyyyy...)
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 06-03-2015, 09:45 PM
This is my nemesis and naturally it's in the case with the serial number. The serial number that my COA says this is the original motor for my '79 930.
My question is who do you recommend to do the EDM work? I want to get that bolt out without destroying the threads.
Old 06-16-2015, 05:37 PM
3 restos WIP = psycho
kenikh's Avatar
Send it to Ollies
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-16-2015, 05:42 PM
Originally Posted by kenikh View Post
Send it to Ollies
I talked with the folks at Ollies today, seemed very knowledgeable but no EDM. The engine needs to come apart all the way to do the work, if the rods and crank need work I'll send everything there and he can sub the EDM work out.
So far most parts show little wear, tight valve guides and the valves look to have very few miles since being done. New seals and valve springs, hone the cylinders a touch and new rings then the top end will be about ready.
I'm planing to tear down the bottom this weekend and see what is inside.
Old 06-17-2015, 05:36 PM
Looks like you already tried welding on a nut?
Old 06-17-2015, 07:10 PM
Not pretty, cases and crank, cylinders, rods and cam towers headed to AZ for inspection and a good cleaning. Little specs that looked like aluminum imbedded in the bearings and signs of over heating on the mains.
Nothing spun, but an inspection is in order and it has to go anyway for the head stud.
I have my fingers crossed.
Old 06-29-2015, 03:58 PM
Welcome to the nuthouse fellow 79 930 owner...
I split my case and the slippery slope began..After buying new OEM P/C's, sending off the cams, rockers, Heads, crank and rods rebalanced, grind and cleaned , rebuilt back wiring harness, turbo rebuild here shortly and a whole slew new parts, ARP head studs for mine...Not to include new tools, books to make the job easier..I bought new for most parts since I was there...Could have saved a few but hey...I wanted assurance since I do not want to know something crapped out later and 13k later the block is back together. Ready for the cams to be timed...
Keep a spread sheet going and watch the numbers grow ;-)
Cheers and have fun....
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 06-29-2015, 04:38 PM
kenikh's Avatar
Oh, the spreadsheet. Essential. Mine is now epic.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-29-2015, 04:40 PM
