1984 930 Turbo
I have asked this before, but not got any solution.
My engine in good shape after overhaul runs good oil pressure ok, but when staring cold engine outside temp 10 degree C, a knocking sound is heard, the sound idsappear after about 5 mins when the engine goes down on rpm from about 1200 to 800 and noe sound are heard afterward, this is only for 5 mins each time, not regulary, maybee one time every 6 cold starts. I think I have checked every possibility, but not the cam chain tensioners, it could not be the connecting rods since nothing is heard when engine hot. Is this matter so easy that it could be the cam chain tensioners? What to do, should I take then engine out or wait for some more seriuos things to happen ? Regards lexn ![]() |
Grab one of these and you will be able to isolate where this noise is coming from better.
Amazon.com: Lisle 52750 Stethoscope Kit: Automotive |
Rey....77 930 "the Mistress" |
check valve adjustment
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Banned
good tip Rey - mine does that on cold start and it subsides in a minute or so, and the sound could be deceiving
comes from a header flange that's not fully square, I've tried retorquing it but it's best it's going to get I wouldn't think valves out of adjustment sound would dissipate with heat / time best bet Lexn is to post a vid here - we've got surprisingly good ears! 8-) |
"...but when staring cold engine outside temp 10 degree C, a knocking sound is heard",
It's all in the translation. "Knocking" to me means deep, low frequency internal engine knock (Rod bearings). Tapping is an entirely different thing. Valve lash, and/or exhaust leak....two strong possibilities depending on what Lexn is actually hearing.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
