fuse panel pic and/or diagrams
I am finishing my hot rod resto of a 78 930. It was a rolling chassis when I got it along with a large number of parts in boxes. The previous owner seemed to get most things half right. I replaced the old ceramic fuse buses with the newer twin blade set-up, sold by a fellow pelicanite.
I just want to make sure that I reconnected everything correctly and I believe the previous owner might have gotten a few wrong. So pics would be very helpful Thanks, Mark |
(TPIWWP!!! Pics, or VTB!)
8-) sorry it's a bit hard to read - all I's got: <img src="https://lh3.googleusercontent.com/XRszqoSjCMV7NIvcSlsOYoo1QTqytM-Q10kwl7O4zFme=w800-h244-no"height=350width=500> |
thanks for the posts, however I really could use a pic. need to see wire sizes, etc. Some of the wires are color coded the same, but have different gage wire
thanks in advance |
Nice pic Kenik - I have it filed for future reference. I'm sure I will need it, sometime.
Mark, I can take a real live pic tomorrow if no one posts one before. Alan |
Fuse panel
Mark, make sure to post up a picture of your new blade fuse panel. Which one did you use? I was looking at the new one from the UK being offered by pelican but it's pretty pricey and it doesn't separate the fuel pump fuses.
Then it turned in to this:http://forums.pelicanparts.com/uploa...1436636006.jpg
thanks man - helps a bunch
Mark,
I found the '78 wiring diagram in Pelican to be very helpful for even my '86 wiring so it should be good for you. http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_78SC_USA.pdf Wire sizes are included and colors are especially useful. Color print it and paste it together. Good luck. Johan |
Thanks guys these are great! I will put all of these in my research file.
thanks everyone for the help!
| All times are GMT -8. The time now is 05:16 AM. |
