Porsche Crest Fuel lines
Hi all I have seen posts on the forum on Fuel line replacement... I want to replace fuel lines all the way from the tank through the tunnel all the way to the rear on my 1982 930 .. is there a kit available ... do you replace them with steel lines, normal rubber type lines or the factory style lines.. what a job to remove them don't want to do that again...I am running an EFI system,..
Old 09-15-2015, 12:40 AM
dos531's Avatar
Talk to Len, he makes all those lines. He goes by BoxsterGT on here.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
CIS sucks balls
Old 09-15-2015, 08:48 AM
911tracker85's Avatar
contact Len Cummings. he made a full set of fuel lines for me. just getting ready to install.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 09-15-2015, 08:50 AM
Center tunnel fuel line replacement questions
1987 GP White 930
1977 Ford Bronco
Old 09-15-2015, 09:19 AM
Jeff NJ's Avatar
I wouldn't recommend steel braided lines since the path that the lines take can rub up against other things and they will be very abrasive compared to the original lines and may cause unintended consequences. My lines were 26 years old and still working fine when I replaced them this past winter with lines fabricated by Len Cummings. IMO, his setup is the way to go. Perfect fit, high quality and he is available to help with any issues or install questions.
1988 930 Venetian Blue
Old 09-15-2015, 10:43 AM
Banned
as said - call Len, he's da man
You said you already removed your OE lines - you kindasorta boned yerself in that Len sends you your new lines w/ a coupler fitting to affix to the rear of your OE line... so that you grab the front of the OE line and pull it out / pull in the new line.
cross your fingers you'll be able to snake the new line in successfully w/o impingement - good luck
Old 09-15-2015, 07:07 PM
