-   -   where to pout O2 sensor (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/877821-where-pout-o2-sensor.html)
T77911S 08-06-2015 05:06 AM
where to put O2 sensor
I have my header off and for sale and was going to have the joint where all the pipes come together at the turbo tig welded but I would like to add a place where I can measure exhaust gas back pressure.
I was going to put the bung right there below the turbo but I was thinking the better place to know the exhaust back pressure might be at #3 or 6 exhaust port since the pressure of the exhaust going back into the cylinder is critical.
I have seen a back pressure gauge on the 935. Where do they measure it.
If i don't sell the header soon I may change the cams since I have the engine out
Tippy 08-06-2015 08:24 AM
Anywhere before the turbo is all you need since pressure is equal throughout all places. If someone has a better reason to place elsewhere, I'm all ears.
Do you mean exhaust backpressure, or AFR's???
:confused:
T77911S 08-06-2015 09:12 AM
Back pressure. Curious what is. Could effect what cam put in there.
