Brando
quattrorunner's Avatar
Very nice work
Turbo powa!
1977 911s. it's cool
Old 06-24-2017, 11:12 AM
lite75's Avatar
your up next Brandon!
75 930, 76 930, 83 SC EFI turbo
Old 06-25-2017, 07:10 AM
Brando
Perhaps next for efi but don't expect the same quality execution.
Turbo powa!
Old 06-25-2017, 08:25 AM
lite75's Avatar
Cut new holes in the engine tin and installed beading material on the edges, installed the new connection pipe, finished the waste gate dump pipes, installed the lower valance and now its ready to come off the lift. All I need is some fresh E85!!
Old 08-25-2017, 04:43 PM
Brando
That tin is so smooth n nice. Sweet exhaust.
Turbo powa!
Old 08-25-2017, 05:50 PM
lite75's Avatar
First test run on gas, waste gates work perfect. .7 bar springs in place and hold nice and steady.
The 1.06 T4 twin scroll housing spools almost as quick as the old .82 T3.
Old 09-07-2017, 03:54 PM
TurboKraft's Avatar
Congratulations and good job!
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 09-08-2017, 11:33 AM
Brando
Of course it does, parts and work are perfect.
Turbo powa!
Old 09-08-2017, 11:37 AM
lite75's Avatar
Thanks for the compliments, hope to do some tuning soon. Yea!!
Old 09-08-2017, 05:41 PM
lite75's Avatar
After tuning the A/F for E85 and adjusting EBC for some additional boost, as suspected I need more fuel capacity. Ordered 1/2" feed, 3/8" return lines and a DeatschWerks 350 LPH fuel pump. Keep you posted on progress..
Old 11-15-2017, 12:27 PM
lite75's Avatar
New larger fuel tank, hard lines and fuel pump. This is going to be tight with a flex fuel sensor as well..
Old 12-01-2017, 08:04 AM
'76 911S 3.0's Avatar
Man this just keeps getting better and better! Keep up the great work!
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 12-01-2017, 11:55 AM
lite75's Avatar
My goal on this project is to make E85 the primary fuel used with gas only used for storage. Hoping this larger tank will make it a bit easier.
Oh my, replacing those fuel lines in the tunnel Is going to be a challenge..
Old 12-02-2017, 05:54 AM
You got that right. I've pretty much given up pulling -6 aluminum hard lines through the tunnel. I've gotten them in but the ends are so mangled by the time I get them to come out through the front you can't get a fitting on them and there is no room up there to rework the ends of the tube. I think I'm going to try pulling fabric covered hoses through there instead.
1987 GP White 930
1977 Ford Bronco
Old 12-02-2017, 11:10 AM
Hello, there is maybe a solution to increase a little the passage existing in the tunnel.
Chris de TK recommended me 8an to go and 6an for return.
Old 12-02-2017, 11:17 PM
Nice work!
I got two -8 TechAFX PTFE lines thru the tunnel. Nice stuff, but pricey. Conductive PTFE core, stainless braid wrap over the PTFE and a protective cover over the braid so it doesn’t chew up everything. The nice thing, it has the ID of -8 but the OD close to -6 so it fits a little easier.
935 Suspension with Moton Coilovers for the street
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 12-05-2017, 06:44 AM
lite75's Avatar
WinRice,
After playing tetris with the fuel pump behind the tank putting it inside the tank looks more appealing all the time. That fab work is awesome!!
Old 12-10-2017, 05:55 AM
WinRice,
Thanks!
I tried the rigid dual 1/2" line down the tunnel and it was a PITA. Then looked at all the flex options and settled on the TechAFX stuff. Pricey, but should last forever. I only wanted to do it once.....
The wife calls my gas tank the Master's Thesis......LOL It took way longer than I thought with my limited time.
1986 911 Turbo
Old 12-10-2017, 01:37 PM
lite75's Avatar
Fuel lines have been ran through the chassis, front pump mounted, all hoses finished up in the front today. Now back to the motor compartment.
Old 03-24-2018, 03:17 PM
lite75's Avatar
Just finished up the fuel lines in the motor compartment, Used a 85micron filter pre pump and a 10 post, pressure checked the lines and fired it up last night. Still need to fit up the gas filler tube and get a smaller battery but very close..
Old 04-19-2018, 06:49 AM
