Brando
quattrorunner's Avatar
Exciting. Looking amazing.
Turbo powa!
1977 911s. it's cool
Old 04-19-2018, 08:55 AM
TurboKraft's Avatar
You mean 85 pre-pump and 10-micron post-pump and before the injectors, right?
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 04-19-2018, 10:04 AM
lite75's Avatar
Just checking to see who's paying attention, yes that's right.
75 930, 76 930, 83 SC EFI turbo
Old 04-19-2018, 10:09 AM
'76 911S 3.0's Avatar
Originally Posted by lite75 View Post
Just finished up the fuel lines in the motor compartment, Used a 85micron filter pre pump and a 10 post, pressure checked the lines and fired it up last night. Still need to fit up the gas filler tube and get a smaller battery but very close..
Please lose that brass sensor. Those are prone to leaking over time and I would hate to see all your hard work go up in flames over a $50 part. Replace it with one of these in the pressure range you need:
http://aemelectronics.com/?q=products/sensors-connectors-accessories/map-pressure-sensors/stainless-steel-psig-sensors
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 04-19-2018, 01:44 PM
lite75's Avatar
Think I have one of the SS ones sitting on my shelf, I'll put it in. Thanks for the tip!
Old 04-19-2018, 01:56 PM
lite75's Avatar
I've tuned this about a far as I can without a dyno, running great with no problems but I'm sure there's more in it.
Old 07-10-2018, 08:55 PM
juan ruiz's Avatar
I missed this thread completely and in the end? any dyno numbers?
10.76@139-1/4 mile
0-1 mile 193MPH
I Love to Shine Cars
Old 01-02-2019, 08:20 AM
lite75's Avatar
Juan,
I've continued to work on refining the tune this past month. After turning up the boost I noticed a slight dip in fuel pressure that had me concerned. A bigger yet fuel pump, pre pump fuel filter and lines from the tank are being added. I'm hoping to run this on just one pump but we will see. Also working on installing in my in ground chassis dyno to tune this machine, updates will follow.
Old 01-02-2019, 08:43 AM
