-   -   Wastegate boost source question (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/884385-wastegate-boost-source-question.html)
gavinc69 09-24-2015 11:18 AM
Hi guys,
I currently take the boost pressure source line for my wastegate from just after the turbo and before the intercooler.
After getting a larger intercooler and reading a bit more about intercoolers it seems at least some IC's will have a little restriction and cause a very small amount of pressure drop so your not actually getting your full boost pressure to the engine.
Therefore wouldn't it be best if I move the boost pressure source for the wastegate to after the IC so I then get a correct and more accurate pressure reading for the wastegate.
I thought that way it would allow a little more boost to compensate for any pressure loss from the IC??
T77911S 09-24-2015 05:12 PM
my RUF IC has a port on it for the WG.
if your boost gauge still reads the same thing then there is not a problem.
