Alan L's Avatar
blue smoke
On over run = valve guides? Happens between gear shifts - puff of smoke, and downshifts under brakes.
Any other potential source? My leak down numbers are between 93 and 98%. One at 93, rest 96-98.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 10-04-2015, 03:51 PM
T77911S's Avatar
valve stem seals
valve guides
piston rings/oil ring
pull plugs and take a look at them
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-05-2015, 06:55 AM
I had blue smoke on acceleration. Opened her up, changed valve stem on one cylinder, then closed her up. All was good after that. Yours is on decel and downshifts. Not sure if that will be stems.
Here`s the cylinder in question when i removed the headers. Good one to compare.
http://i.imgur.com/V3WZEaj.jpg
http://i.imgur.com/Ss6hEQv.jpg
Gone!
Old 10-05-2015, 09:48 AM
Alan L's Avatar
I had issues with the valve seals when installing. Some of them didn't seem to snug tight - I could pull them off again after pushing them on. I was a bit scared to wack them too hard. The heads were 2nd hand ones I purchased and ported, but the valves/guides seemed in better condition than what I was running. The leakdowns I think are OK - new rings. One cyl may not have bedded in completely. Had another at 93% that has come up to 98 with last track run. I'm thinking valve area on over run, rather than rings?
Regards
Alan
Old 10-05-2015, 12:34 PM
