Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
totle's Avatar
If you replace the 964 crank in the NA engine with 3.0 crank, you have a 3.3 twin plugged 8:5 CR engine, ready to be turbocharged :-)
I would trade
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 10-12-2015, 03:25 AM
puddy's Avatar
Wow that looks like a really fun swap & project, I'd jump all over that to!! That 965 looks badass!
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & outlaw pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 10-12-2015, 04:13 AM
jwakil's Avatar
Seriously, a 965 with a 3.6 motor vs a 993 cab? That is a no brainer. The 965 is probably worth 2X, even without matching numbers.
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 10-12-2015, 09:17 AM
Do eeet !!!
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 10-12-2015, 09:20 AM
Those are some nice pics and I have seen your car, which is just as nice...as you know I prefer old school P-cars ;-)... You need a project and I need to learn more not to mention I need a project as well as mine is done..Jump
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 10-12-2015, 03:36 PM
Cobalt's Avatar
Unfortunately Porsche did document both the tranny and engine numbers which would show in the owner's manual, sticker in the front hood and or CofA. Also by year. Unless you can source the original engine I would not invest in a 964T or 993TT transplant. You would get more bang for the buck from a nice low boost twin turbo on what you already have at a lot less $$ and have a car that would smoke a lot of cars. Although a well setup 964 engine in that body could be all you need to have some real street fun. The turbos are great but not for everyone. You could always invest in a LWF and different gearing LSD etc assuming your brother hasn't done that already.
If you really want to wake the car up narrow body trailing arms, nice suspension upgrades etc would make a huge difference.
These are the kind of problems everyone should have.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, '93 964 C2, '93 928 GTS 5 speed, '94 Turbo 3.6, M '15 Boxster GTS18 Macan GTS
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS many others
Old 10-12-2015, 03:59 PM
My brothers car need some work like the AC system needs some looking at, and a different set of wheels would be nice, maybe 18 inch Speedlines , RSR copies with NA trailing arms, should i do the RSR 3.8 tail or leave the turbo tail ?
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 10-15-2015, 11:22 AM
Totle
Your saying by replacing the 3.6 NA crank with a SC 3.0 crank and leaving the stock 964 P & C's would lower the compression enough to turbocharge this 93 964 NA motor?
1992 964 C2 turbo
Old 10-15-2015, 11:49 AM
Cobalt's Avatar
Originally Posted by heliolps2 View Post
Totle
You can do a low boost .5 bar or less and have all top end seamless power. You can go quite crazy if you want but it is far less costly than opening it up and I have seen these systems run for a long time on the track and even longer on the street.
Trust me I have a 450hp turbo 3.6 and a 450hp twin turbo 993 varioram low boost night and day difference and the twin turbo feels more like a N/A motor than a turbo.
Also if you do narrow trailing arms you have to do deep dish wheels and rs tail.
Old 10-15-2015, 03:09 PM
Who does the best 3.6 NA to single turbo conversion , with out changing the internals, Protomotive ?
1992 964 C2 turbo
Old 10-17-2015, 09:31 AM
jsveb's Avatar
My first point of contact would be Chris Carroll, TK
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 10-17-2015, 10:15 AM
Please keep a eye out for a 965 motor for me plz
1992 964 C2 turbo
Old 10-18-2015, 05:11 PM
Cobalt's Avatar
Good luck I saw a 3.3 l sell a while back for $25k haven't seen a 3.6 in years. Are you planning on adding a G50/52 tranny as well. Figure about $10k for one. Then the driveshafts etc.
Old 10-19-2015, 03:25 AM
Crotchety Old Bastard
RarlyL8's Avatar
You'll just have to keep an open search going for the numbers matching drive train. In the mean time you can enjoy the car with the drive train it has now or turbocharge the 3.6L or add a 930 engine or, or ... I don't see a down side anywhere other than the mountain of cash needed to do these things. I think I'd drive it as-is and save up for the correct drive train, it's going to be expensive.
Old 10-19-2015, 04:03 AM
It's been awhile sense my last post, but that's what happens when you drive a 993 NA car nothing to report,
I have a update on the 965 trade, I just got back from a test drive in AZ, AC works..
thank god..
Its a true 1992 964 Turbo one of 289 built that year, Blk on Blk full leather interior and trim, two owner car with 48000 miles,
Starts and drives great and that 3.6 NA engine feels peppy the engine sound different than the 993, I'm sure the hydraulic lifters have something to do with it, it feels like it may need to be corner balanced, my brother installed H &R lowering springs, it feels off.
The 3.6 Na motor has one exhaust outlet on the right, and the 965 has dual outlet bumper, looks bad, so i will need a dual out muffler for a 964 .
Here's whats wrong with the car, It Leaks power steering fluid from somewhere around the reservoir, should be a easy fix, rear lighting need to be replaced , they look pink, the read deck is warped, because of the AZ heat and it's leather
The brakes on the 965 use a electric hydraulic pump system, the brakes need to be bleed correctly, it's a process,
The gear lever has a weird thing going on , a first the gear lever acted normal, as drove the can for a while the gear started to get sticky, like the linkage is rubbing or catching on something, maybe the tranny mounts are going bad, or the tunnel cover is pushed up onto it,
The tires are shot and dried up, the wheels are ok, but a set 18 RH's would look better, but for now they will stay, the front bumper and hood is pitted really bad , like he drove behind a gravel truck for a hour the rest of the paint looks great, and there's a door ding on the driver door,
over all not a bad car.
So looks like I have something to work on this spring, I will post pic's when she arrives.
thank you guys for your encouragement on doing the trade.
1992 964 C2 turbo
Old 03-10-2016, 06:30 PM
Here's some pic's from my visit to my brothers
1992 964 C2 turbo
Old 03-10-2016, 06:49 PM
1992 964 C2 turbo
Old 03-10-2016, 07:00 PM
1992 964 C2 turbo
Old 03-10-2016, 07:02 PM
1992 964 C2 turbo
Old 03-10-2016, 07:06 PM
onboost's Avatar
AC works..thank god..
Yep, nothing dramatic here, all reasonable fixes.. Also, if adding the turbo set-up seems like a daunting PIA, there is a TPC supercharger for sale on the board.
There are a couple of 964's and 993's around the area that are running the TPC set-up. Having driven two of them, I'd say the feeling is quite linear, similar to that of the TT but with a bit less rush.
RGruppe #180
Old 03-11-2016, 04:26 AM
