Stiff steering with the cold weather change?
Drove the 930 this morning, instantly noticed incredibly heavy steering. Hadn't driven the car in maybe a week.
After it sat out on the sun for a couple of hours and the day warmed up it was back to normal. Ideas? Beginning of the summer I re-greased the steering rack. |
Tire pressure lower when cold.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
Old thick grease in the rack.
You should get under there and check out the rubber boots on each end of the steering rack. They eventually dry out and crack and let dirt and rain water spray in.
It takes a little time to remove the rack, clean it up, restore it and then replace the two rubber boots but a new rack is expensive. |
