Front windshield seal for 89 911 turbo help
Hi guys,
I need your help , regarding the windshield seal for the front windshield glass. There are 2 choices there is one w/ molding and one w/ out molding. Im confused. W/c one is for the 89. I hope someone can post a picture w/ one w/ a molding in the windshield seal & one w/o. I have to remove my windshield to take care of a small amunt of rust in the area near the wipers. Thanks in advance, Tdh888 |
If its a late 89 it takes the 964 windshild and rubber no molding
If early 89( mid 88) Takes the one with molding |
Banned
Do a search on tech forum. I think u can use either seal. Been a few
Threads on this subject |
look at your rear glass , it should match, if the rear has molding then you need the front to match with molding,
Helio
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
and if dont have a rear glass then check your rear quarter glass, same thing applies
Rear glass should match
89 1/4 windows all have moldings |
Mine is 87 and it has molding. Not sure with 89. Hope this helps.
1987 Guards Red 930 - TurboKraft Modified |
I was told the the window seal w/o molding is for the C2 and up.
Nope it started in 89 models 911 turbo and the 964C4
Thanks for the picture ! Mine does not have that molding. Now I can order the correct part.
Thank you very much guys for the replies , Tdh888 |
This is correct. I recently replaced the windshield on my (late) '89
Ole Skool - wouldn't have it any other way |
