-   -   Another 930 introduction (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/896720-another-930-introduction.html)
kevin.bodman1 01-07-2016 11:57 AM
Is this a good turbo for the 930?
Sent from my SM-N910T using Tapatalk
Ronnie's.930 01-07-2016 04:25 PM
Kevin, a base model K27 is considered a good, basic upgrade turbocharger - spools considerably quicker than the original 3ldz, but does run out of steam at higher rpm (so does the 3ldz). There are several modified K27s on the market that keep on chuggin' (different than how Paul chugs "you know whats"! :eek:), so it will be interesting to see if anyone can ID what you have.
kevin.bodman1 01-08-2016 10:22 AM
What is a twin scroll turbo.My impression was two turbo in one controled by a valve.But then again i married two diffrent women with the same first name.[emoji85]
kevin.bodman1 01-12-2016 06:34 PM
How do i remove the white faces on my gauges,any suggestions.thankshttps://uploads.tapatalk-cdn.com/201...b7ce9d929b.jpg
kevin.bodman1 01-13-2016 10:10 AM
