Torque Values for '80.5-81 front Floating Rotors
Thought it best that I post this in this turbo forum.
Just installing new '80.5-81 front floating rotors on my RST build. Anybody know what the torque values are for the 12 M6 and 5 M8 bolts that attach to the hat? http://forums.pelicanparts.com/uploa...1451847682.jpg Thanks in advance. Cheers, Johan |
Anyone? Please.
Johan |
To be honest its not really that critical. if I had access to the little pocket spec booklet in my car I could look it up for you. its in there.
Just make sure its hand tight using common sense and bend over the 12 little locking tabs to keep the M6 from coming lose. The M8 can be joined with nylock nuts if you want to be sure they stay in place. Fred |
Fred and stevie, many thanks for your responses. I'm good to go. BTW, Stevie's pics shows my rotor/hat setup which I always thought (apparently incorrectly) was also used for the '81 model year.
Cheers, Johan |
I did mine @ 10ftlb after 3 use they stretch, need to change to new one
| All times are GMT -8. The time now is 05:11 AM. |
