I wanna know: How is a chip designed without the car on a dyno?
I just realized that i do not understand how a chip gets designed.
I have several questions that I know there are a bunch of you who know the answers. 1) HOW can the chip-makers just ask you for the octane you use, and exhaust system, and injector size maybe, and a few other factors, and THEN design a chip for you. 2) Is there a software program into which one inserts a bunch of variables, and it then designs the chip? (Is this how Steve Wong does it -- distance-learning?) 3) Given the mods that most of us do to the car (including reducing car weight, tire size, etc.), how can there be a chip programmed for the car without the car actually being "measured", like maybe on a dyno?? 4) How in the world do you know if the chip you got is the ideal design for your car? Certainly one's seat-pants-dyno is pure guesswork. Appreciate some insight. Thanks. |
Very simple, they've made the tunes before from other vehicles, then saved the data.
Doubt a tune is estimated, but you could if you knew the VE difference one engine makes from the newer part(s). Is it perfect? No, but even with say hypothetical 15% variance (would be extreme I'd imagine) between 2 different engines with the exact same parts and bits, it'll be good enough to drive fine. |
This is why customizable EMS are so nice. You can keep on tweaking.
Chip, on a 930?
My understanding is Steve Wong offers the same, price unknown. |
Thanks for the responses.
Customizable EMS makes the most sense, however, I think this will be far down the road, because this Porsche is just a project, never intended to race (and possibly never intended to drive! --- yah, it's one of THOSE cars).:mad: |
You can run an MSD BTM (boost timing master) to retard timing under boost and a BEGI (Bell Engineering) rising rate fuel pressure regulator to raise fuel pressure under boost not requiring a chip.
| All times are GMT -8. The time now is 11:41 PM. |
