-   -   Another 930 teardown (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/900557-another-930-teardown.html)
boosted79 01-29-2016 04:49 PM
'79, 80k miles. All stock except the reactors were removed when new. I'll keep it stock except maybe a set of used headers and a K27.
http://forums.pelicanparts.com/uploa...1454114082.jpghttp://forums.pelicanparts.com/uploa...1454114275.jpg
http://forums.pelicanparts.com/uploa...1454114343.jpghttp://forums.pelicanparts.com/uploa...1454114465.jpghttp://forums.pelicanparts.com/uploa...1454114621.jpg
The gas ratchet wins again
http://forums.pelicanparts.com/uploa...1454114801.jpg
JacobS911 01-29-2016 05:25 PM
Excellent! I was just in the garage earlier getting mine ready for my first engine drop!
Alan L 01-29-2016 05:35 PM
I'll post a pic 2morrow of my 1000 pieces.
Alan
Alan L 01-30-2016 03:39 PM
snap
http://forums.pelicanparts.com/uploa...1454197135.jpg
boosted79 01-31-2016 06:19 AM
Nice shop! Wish I had that much room.
911tracker85 01-31-2016 07:39 AM
me too..... and a lift.... actually I have decided to get a rotisserie when ready for paint and then to make it easier to put it all back together....
good luck on your project. SmileWavy
http://forums.pelicanparts.com/uploa...1454254588.jpg
911tracker85 01-31-2016 07:42 AM
PS. I really want a set of Brian's headers, but depending on the funds may need to use these for a bit. but they will go for sale at some point. I have seen other, similar sets of used headers for sale, so good luck on that.
http://forums.pelicanparts.com/uploa...1454254906.jpg
boosted79 01-31-2016 07:51 AM
Anything will be better than the reactor replacement manifolds I've got now, they look like something off a diesel tractor. But they are well made, I'll give them that. I'm saving the serious money for the hot rod build on an '87 slant conversion.
boosted79 01-31-2016 07:55 AM
" actually I have decided to get a rotisserie"
Make one out of two engine stands.
911tracker85 01-31-2016 07:58 AM
yea I have seen that and was suggested by Merlin.
have seen what looks like a nice one, very adjustable, for $800. but not ready for it yet..
Alan L 01-31-2016 10:09 AM
You are allowed some toys in retirement. I often think of the 30+ yrs crawling under cars etc - no more. :-) My shed - with the upper floor- is near as big as our house. As it should be.
Alan
boosted79 01-31-2016 10:57 AM
Ha,Ha, I agree. That's why I bought the Maxjax lift. Yes, 1500 ft2 house with 4000 ft2 shop is what I would prefer.
Alan L 01-31-2016 11:12 AM
I just need to shift a bed and beer fridge into my shed, and I could live there - if things came to the worst :-)
Alan
Alan L 01-31-2016 11:19 AM
couple more pics
http://forums.pelicanparts.com/uploa...1454267830.jpg
http://forums.pelicanparts.com/uploa...1454267893.jpg
http://forums.pelicanparts.com/uploa...1454267960.jpg
phrogs 01-31-2016 03:20 PM
Damn why couldn't I find a blue one!
what blue is that by the way?
TURBO TALES 01-31-2016 03:30 PM
looks like Minerva Blue! my favorite color for sure!
boosted79 01-31-2016 04:15 PM
Yes, Minerva Blue. No sunroof. 95% original paint, quite a few stone chips on the front though. Original owner was from NJ, so it probably spent a lot of time on the NJ turnpike in bumper to bumper at 75.
boosted79 02-03-2016 05:48 AM
I've never liked hanging any engine off just one end. I'm sure this is opening up a can of worms and correct me if I'm wrong but that factory style ring with the lip does nothing to counteract the weight of the engine trying to pull the top stud out of the case. The lip eliminates the vertical shear force in the studs by supporting the case but I don't see how it helps with the bending force of the engine weight pulling on the top stud. Obviously the one stud is sufficient since the yoke has been used forever, this is just the way I like to do it. http://forums.pelicanparts.com/uploa...1454507180.jpg
911tracker85 02-03-2016 06:02 AM
LMAO .... my grandmother used to say, "let me show you how I do it."
not meaning to imply anything, just struck me funny. SmileWavy
good luck. as I am distracted by a couple smaller projects, my 930 engine tear down is at the point in your pic and will stay that way for a few weeks.
boosted79 02-04-2016 05:23 PM
The propane torch and pipe wrench took care of the head studs. The pipe wrench bites best on the threads but I had to move it down to the shank for a few tough ones. I put some torque on the stud and then just held the torch on it until it let go and then kept the torch on until it was almost all the way out. Don't rush it, let the heat do the work. The four studs closest to the flywheel were the toughest for some reason. The two on the oil pump side can be heated from the back of the case behind the flywheel in addition to inside the cylinder spigot. http://forums.pelicanparts.com/uploa...1454634718.jpghttp://forums.pelicanparts.com/uploa...1454635218.jpg
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
