LinkBack | Thread Tools | Rate Thread |
Another 930 teardown
Excellent! I was just in the garage earlier getting mine ready for my first engine drop!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 - Kokeln Intercooler - RarlyL8 headers/muffler - Leask WuR - Tial 46mm - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Wevo engine mounts - Rebel racing transmission mounts '99 4Runner Sr5 |
I'll post a pic 2morrow of my 1000 pieces.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
snap
Nice shop! Wish I had that much room.
good luck on your project. ![]() ![]()
Bob Cox 84 928S, Ruby Red linen/brown interior - preferred DD 85 911 Targa, White Gold/brown int - sold ![]() 86 944 turbo my new DE/track car. 78 930 clone project car. |
PS. I really want a set of Brian's headers, but depending on the funds may need to use these for a bit. but they will go for sale at some point. I have seen other, similar sets of used headers for sale, so good luck on that.
Anything will be better than the reactor replacement manifolds I've got now, they look like something off a diesel tractor. But they are well made, I'll give them that. I'm saving the serious money for the hot rod build on an '87 slant conversion.
" actually I have decided to get a rotisserie"
Make one out of two engine stands. |
have seen what looks like a nice one, very adjustable, for $800. but not ready for it yet..
You are allowed some toys in retirement. I often think of the 30+ yrs crawling under cars etc - no more. :-) My shed - with the upper floor- is near as big as our house. As it should be.
Alan
Ha,Ha, I agree. That's why I bought the Maxjax lift. Yes, 1500 ft2 house with 4000 ft2 shop is what I would prefer.
I just need to shift a bed and beer fridge into my shed, and I could live there - if things came to the worst :-)
Alan
couple more pics
Damn why couldn't I find a blue one!
what blue is that by the way? |
looks like Minerva Blue! my favorite color for sure!
88-930 Black / Tan 89-930 Grand Prix Wht 70 Trans Am Ram Air III 4 speed 74 Bronco Sport 302 Auto Beach truck for the Mutts |
Yes, Minerva Blue. No sunroof. 95% original paint, quite a few stone chips on the front though. Original owner was from NJ, so it probably spent a lot of time on the NJ turnpike in bumper to bumper at 75.
I've never liked hanging any engine off just one end. I'm sure this is opening up a can of worms and correct me if I'm wrong but that factory style ring with the lip does nothing to counteract the weight of the engine trying to pull the top stud out of the case. The lip eliminates the vertical shear force in the studs by supporting the case but I don't see how it helps with the bending force of the engine weight pulling on the top stud. Obviously the one stud is sufficient since the yoke has been used forever, this is just the way I like to do it.
not meaning to imply anything, just struck me funny. ![]() good luck. as I am distracted by a couple smaller projects, my 930 engine tear down is at the point in your pic and will stay that way for a few weeks.
The propane torch and pipe wrench took care of the head studs. The pipe wrench bites best on the threads but I had to move it down to the shank for a few tough ones. I put some torque on the stud and then just held the torch on it until it let go and then kept the torch on until it was almost all the way out. Don't rush it, let the heat do the work. The four studs closest to the flywheel were the toughest for some reason. The two on the oil pump side can be heated from the back of the case behind the flywheel in addition to inside the cylinder spigot.
Thread Tools | |
Rate This Thread | |
