Bucketlist's Avatar
octane
What does the brain trust think about the fuel used in your cars. Do you buy 93+ from the pump or use an additive?
One of the stations in town has started offering 93 and 101 octane fuel from the pump. Since I don't race my car I have felt fairly comfortable with an additive. My current choice is RACE GAS | Racing Fuel Concentrate which I buy in quart cans. Should I change my thinking?
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 03-04-2016, 06:56 AM
Mick_D's Avatar
I like the idea of using methanol and water injection to effectively increase octane and decrease operating temps. How many tanks do you get out of a quart of that? 30 bucks a quart vs 8 bucks a gallon of methanol/water that I can get 2500 miles out of might not be a thing.
Old 03-04-2016, 07:47 AM
Dai Dai is offline
I would mix some 101 with the 93 to get desired octane for both my car and my wallet. That's a great gas station.
1981 black 930 with full 1st gen Gemballa bumpers kit. RUF classic wheels. Modification include: Mode Inc. (Bob Holcombe) full bay intercooler, headers, turbo, and muffler. 360RWHP.
Old 03-04-2016, 07:53 AM
xbmwguy's Avatar
i bet that 101 contains lead. great for our non cat cars, no so good for your o2 sensor for the lm2
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp
Old 03-04-2016, 11:52 AM
Banned
good point, Frank
tho
wb02 sensors are cheap and quick enough to swap heh heh
I like the blend approach on the rare treat it occurs
Old 03-04-2016, 07:18 PM
3 restos WIP = psycho
kenikh's Avatar
100 is typically unleaded. 110 and 118 are leaded.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-04-2016, 07:45 PM
Alan L's Avatar
Lead will kill the WBO2 sensor in a matter of a few hrs.
I used to use Aviation fuel in my race car - highly leaded. Had to go to unleaded when I needed AFR.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-04-2016, 08:37 PM
Bucketlist's Avatar
91 octane is the best premium available around here before this source. I usually add about a quart of Race Gas additive to a tank thinking that should equal about 93+. The cost would be about the same as using the 93 from this pump or mixing 5 gal of the 101 with the 91....
I have always liked the idea water/meth. Any recommendations?
Old 03-05-2016, 04:09 AM
kenikh's Avatar
Snow performance has a good reputation. I've had a few qualifies sources tell me if you use water meth, keep the mixture under 50% alcohol. Something to do with long term corrosion of Nikasil on cylinders.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-05-2016, 06:47 AM
Alan L's Avatar
There are some good threads on water /meth. A well trodden path.
Regards
Alan
Old 03-05-2016, 10:09 AM
lite75's Avatar
If its sold for street use I bet that 101 is unleaded. I ran the unleaded 100 for a while and you can definitely get more power from it with some tuning. However at $8.50 a gallon it makes E85 very appealing.
75 930, 76 930, 83 SC EFI turbo
Old 03-05-2016, 10:29 AM
Mick_D's Avatar
The one I have experience with is Snow, I put a stage III system on a 5.7L Challenger that had a Magnusun 2.3L supercharger on it. It was was configurable in many ways, the simplest of which was a simple analog injection curve that followed the throttle, with a kill switch on the whole thing so if the tank ran dry I could just remove it from the loop entirely. If you aren't running an EMS or a computer-controlled EFI this is probably the best way to go. I think the stage III runs about $1K but a stage 1 would do the above for under $500. Instead of paying $16 or more a gallon for their methanol/water mix, I used windshield washer fluid that was rated for -20 degrees Fahrenheit, which has about a 52/48 mix of water/methanol, costs about $8 at Autozone, and ran for about 800 miles a gallon in the above-described configuration. A fun thing was that since I had it plumbed to the windshield washer tank, I even got a little alert on the dash when the tank ran low.
I never did any investigation into how high an octane boost I was experiencing, mostly because I had no idea how to do it, but I can tell you that the difference between having it engaged and not having it engaged was noticeable in terms of power and throttle response, and if it was a hot day the difference was even more noticeable. In a different configuration using the car's ECU and the Snow programmable controller, I got 41 extra horsepower on the dyno on a day of 92 degrees F with 77 percent humidity. This is pretty good, but the weather conditions here change dramatically pretty quickly and I didn't want to have to retune the car every time the weather changed.
I am probably going to use meth/water injection on my '75S, but before I do I need to get it back from the painter and get the motor running.
Old 03-05-2016, 11:42 AM
