Drivers seat 'jerks' rhythmically every 15 seconds...
A friend who shall remain nameless, reversed the charge cables to jump my 85 Carrera. Large spark, removed immediately, couldn't believe I just saw that! Idiot! Anyway, only effect was that one of the drivers seat motors (I think) jerks slightly every 15 seconds with an audible click. Is this damage to the motor itself? A relay switch shorted? I know the fuses are all intact, and the seat adjusts fine in all directions and angles. Thoughts?
Old 03-28-2016, 11:35 AM
I'm just going to wait here and see where this goes…
Good luck.
Old 03-28-2016, 11:52 AM
Drivers Seat "jerks" rhythmically every 15seconds...
Fair warning, uncontested layups will not go unnoticed.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 03-28-2016, 12:36 PM
Banned
Paul's driver's seat jerks rhythmically every few seconds, butt that is due to the large, cylindrical vibrating apparatus that he has installed in the seat-base.
I hear that his design plans for said device have been requested by many on this forum (the two guys that posted above, for example) - don't know the truf behind (literally) that, though!
Old 03-28-2016, 12:42 PM
Banned
yikes.
Btw, see you in 3 yff. Boarding.
sorry to the op
Old 03-28-2016, 12:58 PM
Banned
Originally Posted by krasuskyp View Post
Boarding.
You wish, ya' fookin perv!!!
Old 03-28-2016, 01:23 PM
Preferred pronoun:Maestro
Norm K's Avatar
Name the seat Ronnie and call it a day.
When in doubt, use overwhelming force.
Old 03-28-2016, 02:54 PM
Banned
I just though of the perfect name for Paul's special seat - the Norm K - whadaya think?!?!
Ha ha, I just re-read your sentence the way you intended it (name the seat me, not a request for me to name the seat) - ya' farkin funnyman bisch!!!
Old 03-28-2016, 03:16 PM
3 restos WIP = psycho
kenikh's Avatar
I hereby christen Paul's car the SS Lapdance
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-28-2016, 03:25 PM
You have all been very helpful! This is not a joke. C'mon. Doesn't anyone have any serious opinions beyond what an eighth grader might burp out?!
Old 03-28-2016, 07:21 PM
Banned
The seat motor has a wire harness plug that connects it to the wire loom under the seat, so I would suggest that you unplug that run the car for a little bit, then re-attach it, and perhaps the motor will then function normally from that point. Also check to see if the wire ends show any signs of overheating and hit them with some sand paper.
PS - my commentary is more of the 8th grader fart variety - a burp is much too tame!
Kenik, with what substance to you plan to baptize Paul's car?!?!
Old 03-28-2016, 08:39 PM
I Wonder
mgro1959's Avatar
Unless it was operating it seems unlikely that the reverse polarity would cause this. Your more likely to have blown diodes in your alternater. You may have arched on the armature so when the armature turns in the motor it has bad contacts. You might try removing motor and test with a battery to see if it runs smoothly. Sometimes when trouble shooting things will happen that have nothing to do with an occurance but arise out of coincidence. Start with the motor. Goodluvk Thanks Rob.
Old 03-28-2016, 08:47 PM
Banned
Good suggestions/thoughts, and along those lines, OP - put a voltmeter on the battery and check to see if voltage spikes above 14.5 volts accompany the seat jerks. That would indicate alternator and/or voltage regulator damage. Also take the battery to an auto parts store and have it load tested to see if any of the cells were damaged by the reverse polarity incident.
Old 03-28-2016, 09:08 PM
Thank you for your input.
Old 03-29-2016, 08:18 AM
You might also want to try posting this in the 911 technical forum if you haven't already. It gets more traffic and fewer d*ck jokes. The problem is not specific to the model cars covered here, so there's a good chance someone over there has had similar issues.
Old 03-29-2016, 09:18 AM
Tags
electrical , jump start mishap , seat base
