-   -   BOVs/MAP/LEASK RPM Swich Signal Source (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/909338-bovs-map-leask-rpm-swich-signal-source.html)
16Volt 04-07-2016 02:07 PM
Hey, I saw some of you are running a dual diverter setup, I will be doing the same.
I plan on running a standard 710N style Forge valve vented to atmosphere on the intake elbow (fabspeed bypass hose). I then have a different Forge valve plumbed into a shortened mid-manifold (slidevalve section removed). This is also vented to atmosphere.
I am new to running two valves so please forgive my ignorance here.
That being said, where are you pulling signal from for both of your valves? Do you run a single line and T it or grab two separate ports on the throttle body? I no longer have a decel valve btw.
I feel like one set of ports off the throttle body pull from above the butterfly and one set after.
Thank you for any help you can provide.
Ronnie's.930 04-07-2016 02:17 PM
Shannon, this does not answer your question(s), butt I don't think a BOV vented to atmosphere works very well with CIS/K-Jetronic - doesn't that cause an extremely "false rich" condition by making the air metering arm move much father downward than is actually required at sudden closed throttle(a huge air leak, in other words)? Or maybe I'm mistaken about that?
16Volt 04-07-2016 03:55 PM
Well upon closing you will get a burst of richness - hence the flames on lift. There really isnt any harm though (to my knowledge). The issues most people relate to venting to atmosphere is cars using a MAP/MAF for mixture control in the ECU. Those car's electronics are expecting to see that air volume re-circulated.
Venting to atmosphere in CIS does not fundamentally change where your air metering arm is to my knowledge. I vented to atmosphere on a CIS-E system (arguably more advanced than the Porsche plain old CIS) and there was no issue.
16Volt 05-23-2016 12:05 PM
Bumping this thread - I want to finish all the vacuum wireing this weekend.
So...anyone? Even if you aren't running a dual setup, where are you pulling signal from? Im considering plugging the port in the intake (965 style) tube and just running the unit after the intercooler and before the TB.
Because people love pics....
https://c1.staticflickr.com/2/1713/2...df42f821_b.jpgIMG_1351.jpg by Shannon, on Flickr
pkabush 05-25-2016 09:21 AM
I can't help with your question but your motor sure looks sweet. Nice to see that Fabspeed hose blacked out. What product did you use ?
kenikh 05-25-2016 11:43 PM
'lektrikl tayp
jsveb 05-26-2016 07:11 AM
Originally Posted by kenikh (Post 9135732)
'lektrikl tayp
Yes, for this application it certainly beats Jaybee Waeld
16Volt 05-30-2016 10:45 PM
Once again...I am surprised by the lack of actual information in this forum.
16Volt 05-30-2016 10:50 PM
Self bonding silicone tape. Goes by the name 'emergency tape' or 'helicopter wrap'. Good for pretty much everything, it will patch a coolant hose in a heart beat.
On amazon its 'x-treme tape'.
Rawknees'Turbo 05-30-2016 11:19 PM
So you're asking where to hook the vacuum signal hose for the aftermarket BOV(s), correct?
If so, any place after the throttle plate (otherwise, no vacuum to operate the BOV). If it were mine, I would use the nipple (such a great word right thar!) on the throttle body that used to supply the vac signal for the vacuum limiter (decel valve), and then a "t" to supply a vacuum signal to both BOVs.
I guess we have different ideas of what constitutes "information", as I have learned more about 911s & 911 Turbos on the Pelican forums than anywhere else by far (also get to enjoy a lot of laughs while doing so).
krasuskyp 05-31-2016 04:09 PM
Um, wut?
Yeah... ummmmmmmm, no.
(says the guy consciously running a 710N lol) :D
Aren't you an Audiot???
Ps. I didn't know Rawknees' nickname was "Port"?SmileWavy
krasuskyp 05-31-2016 04:36 PM
pps.
Intarestin technique @ attempting to garner assistance, to boot?
Rawknees'Turbo 05-31-2016 07:38 PM
Any port in a storm, bub!
Craig 930 RS 06-02-2016 11:07 AM
This forum is like Jr. High, mixed with a dollop of community college, with a tad of debate class and philosophy class ............ mixed with great information, lol
Hams930T 06-03-2016 12:27 AM
You can run it off one port off the TB and "T" the line. That's not a problem.
- Chris.
