-   -   Bulletproof Airbox 78-83 for Superchargers and Turbo's (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/909565-bulletproof-airbox-78-83-superchargers-turbos.html)
awjens 04-09-2016 02:09 PM
The airboxes boxes are done, I still haven't weighed it yet. It comes in two pieces. The replacement for the lower portion of the airbox (if not using CIS) and the replacement for the upper portion (for use with factory CIS). This was made for boosted applications but will work either way. It can have the Pop-off-valve set at a large range of pressures, or it can be assembled without. It uses the fuel distributor from a stock airbox for the cold start valve. It is tig welded, vacuum tested, pressure tested and anodized. They are made from precision details and assembled on a jig. O-ring seales used thru-out.
http://forums.pelicanparts.com/uploa...1460239461.jpg
http://forums.pelicanparts.com/uploa...1460239482.jpg
http://forums.pelicanparts.com/uploa...1460239495.jpg
http://forums.pelicanparts.com/uploa...1460239504.jpg
http://forums.pelicanparts.com/uploa...1460239522.jpg
http://forums.pelicanparts.com/uploa...1460239534.jpg
http://forums.pelicanparts.com/uploa...1460239759.jpg
jsveb 04-10-2016 07:06 AM
Wow!!!
I would prefer it anodized black, but that is some nice craftsmanship.
cmarkin 04-10-2016 09:38 AM
Another beautiful example of engineering and art as one! I have to ask - is this unit, or one like it (in black, perhaps) for sale?
awjens 04-10-2016 09:27 PM
The boxes are for sale, many colors
We are now making these. they can be anodized many different colors. The test one is now running on the stand. Had a few hickups on starting, I had left a couple vacuum lines open. When it tried to start in these conditions there were a couple backfires. the valve opened and no damage was done. All of the factory connections bolt up, with some extra ports for a MAP sensor, and a air Temp sensor. If you are not using CIS and going to electronic fuel injection, you only need the base part of this assembly. The super charger will be put on tomorrow. It ran excellent normally aspirated, 22 pounds of vacuum at 1000 RPM. No leaks, solid idle, excellent start cold or warm. The factory WUR will be replaced with the Franken CIS unit as well. This engine is running on a test stand.
http://forums.pelicanparts.com/uploa...1460351821.jpg
http://forums.pelicanparts.com/uploa...1460351851.jpg
http://forums.pelicanparts.com/uploa...1460351893.jpg
http://forums.pelicanparts.com/uploa...1460351925.jpg
http://forums.pelicanparts.com/uploa...1460351962.jpg
http://forums.pelicanparts.com/uploa...1460351991.jpg
http://forums.pelicanparts.com/uploa...1460352015.jpg
http://forums.pelicanparts.com/uploa...1460352036.jpg
http://forums.pelicanparts.com/uploa...1460352071.jpg
angelny911 10-06-2016 09:30 AM
chime....... like to see supercharger mounted
Dr J 10-06-2016 10:24 AM
Very nice work! Design should work fine. Here is a pic of my setup which has a similar valve.
http://forums.pelicanparts.com/uploa...1475778224.jpg
angelny911 10-06-2016 11:57 AM
Dr.j in box price on both parts for a 1979 ROW 3.0 with large ports ?
Dr J 10-07-2016 07:51 PM
I'm not the one selling. It's awjens.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
