awjens's Avatar
Send a message via AIM to awjens
Franken CIS
I have a very basic question with Franken CIS. Here's my steps.
1. Purchased tuner studio pro
2. Downloaded Franken CIS firmware from 2015-05-05 zip file on website.
3. Loaded firmware using MS Loader
4. Downlaoded Franken CIS manual
5. Section 3 it says the following
System Setup and Tuning
After loading the project and connecting to the microsquirt as per the main manual, the screen
should look similar to the following,
What project, what main manual is this referring to. isn't there a tunerstudio project that matches this firmware load already created someplace? Do I need to create this screen layout?
Heres what I expected.
Load firmware.
Load project
update ECU definition.
In 5 minutes I expected to see screens that look just like the posts on Pelican.
Connect wideband O/2 purchased from DKUBUS
Connect pressure transducer from DKUBUS
Connect air temp sensor from DKUBUS
Connect fuel injector from DKUBUS
Connect Franken CIS block to engine purchased from DKUBUS
Old 04-17-2016, 08:00 AM
awjens's Avatar
Errors
Old 04-17-2016, 11:13 AM
awjens's Avatar
Franken CIS Picture for Steve
Old 04-17-2016, 06:27 PM
umop apisdn
Those warnings are normal on the first load and can be ignored
subsequent opens after saving the project should no longer complain
the version number and gauge layout on the last screen shot looks good
1981 928S 4.7 ROW with KE3-Jetronic
"Be the man your dog thinks you are."
www.FrankenCIS.com
Old 04-17-2016, 07:30 PM
