did not mean to question the question, sorry if it came out that way
Not sure if it was already mentioned in the posts above but you also make sure there are TWO vacuum connections on the manifold below the itb's. One for the brakes to go a common line that feeds the vacuum booster for the brakes. The other port will need to supply everything else like idle air bleed valve, vacuum signal for the boost controller, etc. Others feel free to chime in but I didn't want to put the brake booster in the same vacuum circuit with the idle air bleed valve. If that ever leaked or stuck open you have runaway throttle along with no brakes.
here are a few pics of what I meant by two vacuum ports.
http://forums.pelicanparts.com/uploa...1461681687.jpg http://forums.pelicanparts.com/uploa...1461681731.jpg http://forums.pelicanparts.com/uploa...1461681751.jpg http://forums.pelicanparts.com/uploa...1461681773.jpg |
Ken, How do you get an intake nut on that one? Looks a little tight.
Great looking manifold adapters. I agree about the power brakes. I always run a separate line circuit. |
wasn't easy, had several like that the notch is larger than the nut stud the nut in the slot and then set the manifold over the stud and tightened it up. If I were to have a do over they would be about a half inch taller I think.
Do you have a common plenom you tie all the signal ports to?
yes just haven't fabbed it up yet. One for the brakes and one for everything else.
| All times are GMT -8. The time now is 01:01 PM. |
