-   -   CIS Flow mods, who can help/enlighten (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/912066-cis-flow-mods-who-can-help-enlighten.html)
awjens 05-04-2016 07:57 PM
This engine has JE pistons. 8.5 cr. It ran without twin plugs. It has, turbo oil pump, aftermarket rods/bolts, raceware fasteners, ssi, mile miglia exhaust, water/air intercooler. Large front oil cooler with fan, oil coolers in both rear fenders. With the additional injectors it ran 1.1 bar 11.7-12.5 AFR observed on all 8 o2 sensors. It has a ks-3 knock detection system. It weighs 2450. The problem was the fuel in the airbox.
awjens 05-04-2016 08:01 PM
Originally Posted by Porschephd (Post 9105256)
Once you get the head done you will need to address the flow in the intake/intercooler, etc. I suggest EGTs on each header bank and then figure out how you are going to even the flow. The intake will flow inconstantly on the outer runners. If you are running a single 02 you are going to show that you are safe once you get to where you want to go...the reality is you are still leaning out cylinders and will break a ring or burn a hole. You will be running a cumulative AFR.
FWIW we did all this many years ago and supported the HP we wanted. Larry still does it and if you called him and said here are my AFRs and here is what I need he would build it. Larry is one of the best people I have ever known. That said the reason we started doing EFI is the cost of tooling up and covering every component that needed to be modified was far greater than then swapping to EFI. Not to mention driveablity and fuel economy was far better. I could lean an injector back at cruise (good injectors) and get 28MPG. In the end it was cheaper and when you wanted to add a new turbo or modify the car again it was a few hours on the dyno tuning.
Since the market has gone nuts (still Baffles me) few are touching these cars. In fact I have one in the garage right now the guy wants back to stock. From a business standpoint makes little to sense compared to 10 years ago.
I have a set of test pipes with 8 wideband o2's and gauges. Also 6 egt's adaptors for air pump holes. I ran this setup before with 2 injectors upstream of the airbox. It worked until on day.... backfire and end of the airbox. New design airbox with blow off valve. I don't want fuel in the airbox.
kenikh 05-04-2016 08:15 PM
^ Sounds fantastic
boosted79 05-05-2016 04:05 AM
That is a nice engine. Water /air IC? We need pics! So you've run it already as a turbo? Did you dyno it? What turbo? I am planning a 3.4 930 build if I ever finish up the present 3.3. I was going to run 8.0 with EFI but you guys say you can do 8.5 on CIS and not have it burn down?? And without twin plug? You are braver than I am.
awjens 05-05-2016 09:52 AM
It is supercharged, not turbo. I never had it on the dyno. I am looking to see if I can find an engine dyno in Saginaw Mi area. There is a place in northern MI that has a chassis dyno. The problem is all this testing and changing CIS parts is time consuming when the engine is in the car. Out of the car all the accessories intercooler, oil coolers etc. makes engine dyno tough. I have seen how much dyno tests change. The engine, oil temps. MAT temps all affect the dyno. First run looks good, second better, third even better..... the next day 40HP less. Different ambient, things not warm etc. I quickly learned dynos are only as good as the operator and repeating the environment. I have seen heaters on rear diff/transaxes, transmissions etc to maintain consistency.
I don't really care what it produces. If it reliably makes 350HP without risking damaging itself in any ambient temp, I'm happy. This is why I went with FrankenCIS and the MS. I want to keep CIS and I just need more fuel. If I learn how to get 700HP worth of fuel thru CIS then everyone on this board learns.
There is a shop in Saginaw that does ceramic coating and powder coating. This guy is also an engine wizard. He was teaching engine design at the local university. I went there to drop off my exhaust parts and spent two hours in his shop. He knows a lot of people in the design/racing arena in that area.
Currently Im getting about 245-250 CC/min thru the stock euro distributor. I need 360-400 cc/min. they say a stock CIS can flow enough to support 300HP. I don't see it in my flow tests on standard or Lamda heads, but I have not opened up the adjustments all the way. They also say theres 20% in there and if that's the case that comes close to 300HP worth of fuel.
I want 350-400 without opening the adjustment screws so I can attempt to balance AFR's on all 6 cylinders.
Currently the first limit is the nozzles, they are the deciding factor on the current flow. I am not going to open them up until I fully understand the relationship between the slits and the nozzles.
The shop has decided to make matching metering spools and pistons. They will blank them out at a cost of 450-500 each. I'm gonna start with 6. The nozzles are next. Much easier to make. They wont have holes so of the two pieces they are much cheaper to play with. Once the slit is EDM'ed I have committed to a 500.00 test. At that point if I don't get desired results I can try a variety of nozzles.
If all goes well and I can get it in the first attempt, I will have 5 spools left. I don't have a turbo spool yet, so before they start MFG I may make 3 SC and 3 turbo. If I don't locate a turbo spool soon I will make all SC spools. I only need one for this car. This wont be the last one I build, but I'm running out of time. My window for dedicating a lot of time to this project on this car is closing.
awjens 05-05-2016 11:07 AM
Does anyone know if the 930 metering body/spool is the same as the SC head. I need to get MFG going on these and I don't have a 930 spool yet. Looks like Tuesday. They are wanting to start machining today or tomorrow. I need to have them to EDM by next Friday. This leaves time for hardening and finish fit/lapping. If someone has one that they can dimension with Mic's it would be quick to see if they can use the same blanked spool/piston assy. I want to make some turbo spools for the 930 guys that are helping. If anyone has a junk SC head there is another test I want to try, modifying the slit on the high end and slightly opening up the nozzles. I could do this over the weekend and run it in the engine currently on the test stand. Before anyone goes negative on me, I just want to see the results on a running engine hoping for more up top, without affecting idle.
boosted79 05-05-2016 12:19 PM
A blower, now this is getting really interesting, instant boost. Now I understand the SSI's, thought you may have made them into turbo headers. That will be a fun street engine. To make say 350 net HP you're going to need close to 400 gross, the blower will take 40 or so.
awjens 05-05-2016 02:43 PM
I did a significant amount of testing on the blower, running different ratios powered by an AC servo. At 1.5 bar it consumed <25HP. I have experimented with different crankshaft/blower ratios with a clutch, making variable boost. That clutch has horsepower limitations.
awjens 05-05-2016 02:45 PM
Anyone know if a 2.7 fuel distributer 438 100 006 has same internals as 3.0 units? A -077, 031 097?
awjens 05-05-2016 03:05 PM
Don't need to reply, I bought it on ebay, I will know next week. I can clean it, flow it and have more data either way.
boosted79 05-05-2016 04:42 PM
Is it a Roots or a centrifugal?
awjens 05-05-2016 08:32 PM
roots
Tippy 05-05-2016 08:52 PM
Originally Posted by awjens (Post 9108573)
roots
Eaton?
awjens 05-05-2016 09:09 PM
I have 3 different Whipple chargers. I'm putting the 2.1 on for this test. It is NLA.
Tippy 05-05-2016 09:26 PM
Oh, screwcharger
boosted79 05-06-2016 03:53 AM
Very cool, screw compressor. Adiabatic efficiency the same as or better than a centrifugal but w/o the lag. When you get the fueling right you need to get it on a dyno. Should be an almost flat torque curve, that car will be a ball to drive. OT, I started up a H2 plant once that had 11 Japanese screw compressors running at close to 14 bar. They were oil flooded though, no timing gears, one screw drives the other.
awjens 05-06-2016 09:15 AM
It amazes me the things I see pelicans have done to these cars. All kinds of creative thinking on here. Lots of ways to get the same results. If I was keeping this car, I would go way beyond what I am doing now. I want it right, and reliable. IfI dyno it it will most likely be on a chassis dyno. Too much complexity to take all this crap.
I am still looking for fuel heads or info anyone has on where I can get some "junk" ones. I bought two this week. I just want the internal parts. I may be able to get the fuel I need without using a newly MFG spool. If that's the case I will be selling the ones they make. I am in a time crunch on the engine. I was hoping not to destroy 3k worth of spools to get what I need on this car. But if that's what it takes......
boosted79 05-06-2016 09:31 AM
You are not keeping the car??? That's a lot of work just to get rid of it!
awjens 05-06-2016 02:10 PM
Yes it is.... and it all started with a blown up airbox....
boosted79 05-17-2016 09:18 AM
Anything new?
