intake manifold 76 turbo aluminum or magnesium
is the intake manifold on a 76 turbo aluminum or magnesium ?
Old 02-06-2020, 06:55 AM
Ingenieur
The lower intake (the part that bolts to in the injector blocks) is aluminum. The upper intake (the part that has the bypass valve) is magnesium.
Old 02-06-2020, 07:04 AM
great thanks that's what i was hoping.
Old 02-06-2020, 07:55 AM
lake wales fla
Fast check for magnesium
Not sure where you got your info on the 930 intake but its not correct.
All 3.0, 3.3 and the 3.6 turbo manifolds are magnesium. The upper section of the air flow meter that mounts the fuel distr. is aluminum but the lower section, the bypass valve housing and intake are all magnesium. If you pick up a bare manifold its obvious that its not aluminum as they are very light.
To do a quick test to determine Mag. from Alum. take a razor blade or sand paper and clean off a small spot down to bare shiny metal and put a drop of vinegar on it and if its Mag. it will start to fizzle . If its alum. nothing will happen.
Make sure you flush the vinegar off good with water.
So the answer to the OP's question is the manifold is magnesium.
Old 02-08-2020, 06:56 AM
kevinbodman930's Avatar
Thats right
Sent from my SM-N976U using Tapatalk
Old 02-11-2020, 12:12 AM
Banned
All Mg.
William.
Old 02-19-2020, 07:08 AM
Ingenieur
Oops. My bad. I forgot all about that. Here is mine going through EFI conversion. It looks aluminum, but it is not.
Old 02-23-2020, 01:09 PM
