Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Jeff NJ's Avatar
Great idea guys. Does the bung extension (ohh, if only Ronnie were still around...) pull the actual sensor out of the exhaust path? Wouldn't that affect its ability to read the AFR?
1988 930 Venetian Blue
Old 05-20-2016, 03:00 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Yes, it moves it up, out of the exhaust path, but the part of the extension that screws into the hole () has holes/chambers in it that draw the gasses in - no effect on AFR that I could tell.
Also, it does move the sensor closer to the bumper, but there is just enough room for it to work.
Old 05-20-2016, 03:27 PM
Jeff NJ's Avatar
Good point. Mine is pretty tight to the bumper already... gotta check the clearance before I buy the bung extender.
Old 05-20-2016, 03:33 PM
I just measured it (not "it", it ), and the extender moves the sensor back about 30mm/1.25" closer to the bumper.
Old 05-20-2016, 03:41 PM
speednme1's Avatar
This is what I have...heat sleeve..plus I have a heat shield sleeve around the connector (not in the pic)
Rey....86 930 "the Mistress"
Old 05-20-2016, 03:49 PM
Jeff NJ's Avatar
30mm for "it"? My condolences.
I don't know if that will work for me. Here is my sensor and the corrugated bend at the end is just touching the heat shield.
Old 05-20-2016, 03:50 PM
Ha (ya' beach!)!!
No way would it work since you are running the factory heat shield, Jeff. I have an aftermarket rear valence and do not use the factory shield (stick on heat shielding instead, that you can see in the pic - works great).
Rey's set-up looks good, too!
Old 05-20-2016, 03:54 PM
Jeff NJ's Avatar
Originally Posted by speednme1 View Post
When I had my last wideband kit...I lost the sensor twice and once on the new system. These turbos can get hot. Now I use a heat sleeve around the wiring near the muffler....no issues.
Rey, do you have a pic or any info so I can look into getting that? Rawknees solution wont fit for me.
Old 05-20-2016, 03:57 PM
speednme1's Avatar
Can't really remember where I purchased it........but I do have some left....what length do you need? I'm sure I have enough. Free of charge. Pm me contact info.
Old 05-20-2016, 04:20 PM
Holy layups with that "length/need" stuff, Rey!!!
And just for others' future references, all types and sizes of heat sheething (wire and hose sleeves) can be bought from aircraft supply places.
Old 05-20-2016, 04:24 PM
speednme1's Avatar
Get your mind out the gutter scabknees...lol
Old 05-20-2016, 04:33 PM
Rey, one of my intertet pals from the Marketplace forum would call that free-be offer "forum dating"! Not that there's anything wrong wiff dat'!!!
Old 05-20-2016, 05:54 PM
speednme1's Avatar
Originally Posted by rawknees'turbo View Post
rey, one of my intertet pals from the marketplace forum would call that free-be offer "forum dating"! Not that there's anything wrong wiff dat'!!!
lmao!!!
Old 05-20-2016, 05:56 PM
Jeff NJ's Avatar
How did I end up on a forum date?? Lol
Rey, that's super generous of you! I don't know what it's supposed to cover, so I'm not sure how long.
And at the risk of further grief from a certain member with bloody knees and a sore throat, do you still live in jersey city? Maybe we could meet up. I work in parsippany...
Old 05-20-2016, 06:12 PM
You should see the callouses - like slabs of beef jerky, I tell ye'!!!
Because you've got it like that, buttofcourse!
Old 05-20-2016, 06:15 PM
speednme1's Avatar
From the sensor to the connector of the sensor is how I have it wrapped. I live next to East Brunswick.....5 miles south of exit 9 on the pike. Maybe mailing it would be better...unless you rather meet up but I'm doing physical therapy 3 times a week for the next month and a half..so maybe on the weekend
Old 05-20-2016, 06:39 PM
Jeff NJ's Avatar
Got my new sensor today (Amazon Prime rocks!) and had to plug it in to test it tonight.
Solved! As all you smart people already knew, it was the sensor. Rey is generously sending me some of his spare heat shielding and then I'm back on the road with a working AFR gauge.
Old 05-23-2016, 09:20 PM
Good to hear thar, Jeff!
Now I'm eagerly awaiting (not like THAT!!!) to read about you sluething out yer "pumps on wiff key" situation. Speaking of which, no need to recount the details of yours and Rey's heat shield give and take exchange, bro (keep that between youse twos)!!!
Old 05-23-2016, 09:49 PM
Work in Progress
Rich76_911s's Avatar
That's awesome Jeff! Nice easy solution.
Nice pics of the car in the 930 POTD thread as well!
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 05-24-2016, 09:15 AM
Jeff NJ's Avatar
Thanks Rich!
Old 05-24-2016, 11:47 AM
