-   -   What a highly modified 930 can actually accomplish (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/919907-what-highly-modified-930-can-actually-accomplish.html)
Jerry S 06-28-2016 06:28 PM
Hi Guys,
Many moons ago, I discussed the types of mods that my buddies car has and the results with the way the car now runs. Ed's car has a Kevlar clutch and aluminum pressure plate coupled to an engine built to the following specs:
3.5 litre P&C with wider spigots to accomodate (7.5:1)
GT3 Oil Pump and Additional Oil Coolng MOCAL
Evo GT2 Cams
Carillo Rods
H20 Inj
EFI w/3.2 manifold PORT AND POLISH to flow match expanded head ports SDS system
Heads ported to support and TWIN PLUG
TIAL Wastegate
GARRETT 3586
GHL HEADERS
Full Bay Intercooler
The video below is the fruits of the labor, and is a good comparison as we chased down a 918 Spyder on the track.
https://youtu.be/9fF8tzlqaB8
Any body have something similar and an approximate HP estimate on this build as we have not had it dynoed.
Tippy 06-28-2016 07:18 PM
The max the turbo puts out hp wise is your hp limit.
Being he's running 1.5 bar, that Garrett is maxed at the ~650hp unless he's running E85 and/or methanol injection.
That turbo is too small for his build. GT40 or bigger would wake it up big time!
GJF 06-28-2016 07:49 PM
That 7.5:1 is killing the response. Nice video, thanks for sharing.
Mick_D 06-28-2016 08:25 PM
I don't see anything unexpected here. Thanks for helping destroy the dream though.
Jerry S 06-28-2016 10:37 PM
[QUOTE]Tippy The max the turbo puts out hp wise is your hp limit.
That turbo is too small for his build. GT40 or bigger would wake it up big time!/QUOTE]
Thanks for that, sounds like he and I are going to have a talk.
What are your predicted outputs with a GT40 based on the rest ??
Raceboy 06-29-2016 01:34 AM
With the modification level so far there is basically no difference whether it is 930, 964 or 993.
So far no one in the Porsche world has surpassed Eddie Bello's 1300 soemthing rwhp and the real life performance of his car. Well, perhaps the 917/30 did but we are talking about real life here :)
Tippy 06-29-2016 04:52 AM
Sorry, didn't see it has meth injection. Yes, the turbos max hp output will be the limiting factor IMO. That turbo used to be big in the 4-cylinder crowd. Now, they've went much, much larger.
Point is, it's a 3.5 with big flowing parts. That engine can support a monster single turbo, or possibly 2 GT28's.
Hell, I spool a BW S366 easily (I'm 3.4, stock Carrera 3.2 heads, cams, and intake). Without an intercooler, I was hitting I believe over 1.6 bar with a G50 in 1st gear.
My S366 would make big power on his, it's capable os supporting 830hp. Happy medium would be the S364 capable of 800hp for less than $750. Of course this would require miss to fit.
I'd look at GT40/42's if sticking with ball bearing.
T77911S 06-29-2016 08:03 AM
you might have been chasing but I don't think that 918 was really running.
it would be like me taking my 930 to a track. I may (try) to run hard every now and then but the car would be driven below its capabilities. for one, I don't want to wreck it.
last half of the video the 918 really left the 930 behind coming out of the corners.
great sounding 930, still liked the vid.
Mick_D 06-29-2016 08:44 AM
I thought the driver wasn't using all the right gears at the right time, either. I really think this video is rare for a reason.
aschen 06-29-2016 10:20 AM
a stock 918 runs the 1/4 mile in under 10 seconds, and does a sub 7 min nurburgring time. It looks like it is running away from the 930 and being paced by the ferrari ahead, even though it is clearly not being driven on the optimum line.
2 cool cars but I think the video confirms just how stupid fast the 918 is
Tippy 06-29-2016 10:31 AM
Watching a video of the 918 going down the 1/4 mile left me in awe. That thing is rocket fast.
It ran 9.80's IIRC.
JakobM 06-29-2016 11:22 AM
1152hp
3.3L
2 x 61mm turbo @ 2 bar
https://www.youtube.com/watch?v=1lyjeOpVRKI&list=PL985A1C95DAA87529
https://www.youtube.com/watch?v=hSLpldcWTqo
No affiliation
JakobM 06-29-2016 11:35 AM
750hp
3.4L
2 x xxmm (proberly some 55mm) turbos @ 1.1 bar
Pat williams has build some awesome 930 engines / cars
Watch this 930 engine/car takes the overall win among the newest porsche in 2008/2009 ...AND only with 4 gear old school 930 gearbox
https://www.youtube.com/watch?v=HlF8x-EaBTs
No affiliation
xbmwguy 06-29-2016 02:17 PM
I'm only a 3.4 with all else the same pretty much. 706 at the wheels
xbmwguy 06-29-2016 02:19 PM
Oops forgot to mention the gt40 :D
TurboKraft 06-29-2016 04:41 PM
We've maxed out the GT3582R at ~620rwhp on a 3.4L running e85. Did over 550whp on 91-octane.
GT3586 -- you're running a different compressor wheel on it, could get a little better... only the GHL headers will choke it.
GT40R could be better if you had twin scroll T04 headers.
Jerry S 06-29-2016 06:08 PM
Great info guys,
looks like there is definitely room for some improvement
Thanks again
Tippy 06-30-2016 08:08 AM
Do you have Xtreme ported heads?
Highway-Star 06-30-2016 10:01 AM
The 930 certainly is modified, however track performance -wise looks it is performing appallingly. At that pace, a minor modifications race class N/A 944 would leave both cars standing. It is challenging to make a fast turbo -track car, with this kind of power it would require a lot from boost spool, suspension, tires, brakes, also driver, to make it work.
Perhaps one would also swap large offset wheels to Fuchs, or perhaps some BBS period split rims, but that is just cosmetic.
Thanks for sharing video anyway, it is very nice when someone does it.
Tippy 06-30-2016 10:28 AM
Yeah, it's tough to keep power steady in a turbo car/930, but I had no problem slaying new Shelby Mustang's with superchargers in the 600-700hp range.
If you can do the same in a 951, that's impressive.
