-   -   need pic of front condensor (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/920059-need-pic-front-condensor.html)
T77911S 06-30-2016 04:32 AM
can someone take a pic of the front condenser lines. I want to see if one has a 45 connector on it.
if possible, can I get a pic of the LOWER port on the dryer. same thing, want to see if it is a 45.
story:
this is about the hose that goes from the front cond to the lower port on the dryer.
I got a new set of hoses but do not have my old ones. I do have a pic of the old one going to the dryer and it HAS a 45 on it.
the new hose has a straight fitting on one end and a 45 on the other. the STRAIGHT end was labeled for the dryer, the 45 was labeled for the cond which according to my pic, the dryer has a 45.
when I connect the straight end to the cond along with the other hose, they do not fit properly. I think BOTH ends should have 45 degree connectors on them.
http://forums.pelicanparts.com/uploa...1467286247.jpg
http://forums.pelicanparts.com/uploa...1467286283.jpg
Pato911 06-30-2016 06:34 AM
The drier gets the 90 at the top fitting and a 45 at the bottom going to the condenser. Both front condenser fittings are straight. They are tight but it fits as your photo shows.
T77911S 06-30-2016 10:04 AM
thanks.
also got a pic from my brother.
his fit better than mine, may try to bend it a little,
looks like a 45 would work better on the front cond.
T77911S 07-01-2016 03:51 AM
the condenser lines bent very easily and I was able to make the hose fit better.
now if I can just find the rest of my parts,
I don't know what it is, I put parts in bags or boxes and I STILL lose crap!!!
I cant find the clamp for the TXV bulb and I don't know where I put the 4 bolts for the compressor.
if you pull everything out like I did, hang on to your old dryer. use it for helping put the hoses back in instead of the new one.,
