Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
That is what I meant when I said "There is also a smaller one where the up-pipe connects to the compressor outlet", bisch.
Old 05-11-2017, 10:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #261 (permalink)
Turbo Powered Snow Blower
Just checking
What plugs do you run? Bosch or NGK
I have the bronze replacement throttle bushings in my cart. Seeing as the OG are plastic I'm sure they are gone.
Thanks, again!!!
Derrick
Old 05-11-2017, 11:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #262 (permalink)
No problem, Deez - it's fun to spend other peoples' money for them, and to keep adding to their "to do" lists.
I have Bosch plugs currently, butt when it comes time to change, will be using the NGK variety that have the smaller sized hex (much easier to work with).
Old 05-11-2017, 11:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #263 (permalink)
Smaller always fits better
Derrick
Old 05-11-2017, 12:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #264 (permalink)
Dont day that to loud Rawknees might get offended.haha
Sent from my SM-N910T using Tapatalk
Old 05-11-2017, 01:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #265 (permalink)
Something tells me that "smaller always fits better" is an ego reASSuring comment you two choads often hear from your significant others!
Old 05-11-2017, 01:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #266 (permalink)
Old 05-11-2017, 02:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #267 (permalink)
Originally Posted by turbo owner View Post
DeezNutzDerrick and CuteButtKevin are not ready for all this!
Old 05-11-2017, 05:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #268 (permalink)
^^^ Stop checking out my Nuts and Kevin's Butt you big perv.
Derrick
Old 05-11-2017, 09:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #269 (permalink)
It's both curious and disturbing that those things often appear in the same line of sight!
Old 05-11-2017, 10:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #270 (permalink)
Ride height is set. I'm about a 1/2" higher than last time. But I am expecting 1/4" or so of settle after I get some miles on it. Bouncing and rolling only do so much. Calipers were shipped Thursday so they should get here Tuesday.
Now onto the valve adjusting.
Derrick
Old 05-13-2017, 09:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #271 (permalink)
How many splines did you end up moving in the back?
Old 05-13-2017, 10:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #272 (permalink)
79 #610 Winter Projects. Advise Needed
Inner spline counter clock wise one and outer spring plate clock wise one. It raised the car an inch or so. Darn near perfect. I did need to adjust the drivers plate up a little and passengers plate down a little. But I don't think I'm off on teeth because he plates were even side to side when checked with a digital angle finder prior to setting it down. Oh and I set everything with the anti roll disconnected.
Derrick
Old 05-13-2017, 11:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #273 (permalink)
As my guys would say.Dude your car looks sick.
Old 05-13-2017, 01:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #274 (permalink)
Originally Posted by kevin930t View Post
As my guys . . .
***forum dating***
Agreed, though!
Old 05-13-2017, 01:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #275 (permalink)
Thanks Bros!
The advice all worked out good. But I would add one thing. Don't use a regular plug socket when removing the plugs. If you are unfortunate enough it will go onto #1 and you will spend over an hour trying to get it off!!
After that the rest went smoothly. Half needed adjusting. Mostly the exhaust were too tight. Scary.
The bronze bushings are already in the throttle linkage. So there's $2.00 down the drain.
I need to order a cap and rotor. They are not in the best shape. I'll just do a full tune up with fuel filter to have a starting point on maintenance.
Derrick
Old 05-13-2017, 04:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #276 (permalink)
Cool about just half of them needing adjustment - that's the thing that is nice about using the backside () method; can easily measure the lash and avoid needlessly adjusting ones that don't need it (unlike using the Kirk tool, pointer tools, and the traditional method with the funky feeler blade holder).
As you are probably aware, the tightening of the exhaust valves that you noticed is typical - combustion pressure pounds them into the valve seats, and combined with the much higher heat of the exhaust 'v' intake valves, the stem/rocker gap tightens with use . . . kind of counter intuitive, as it is easy to assume that the stem gap would increase with use due to wear, butt that is not the case.
Old 05-13-2017, 04:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #277 (permalink)
. . . . and you will spend over an hour trying to get it off!!
Kevin sez, "Two minutes max"!!!
Old 05-13-2017, 04:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #278 (permalink)
2 minutes thats like a marathon.
Old 05-13-2017, 04:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #279 (permalink)
You'd probably need a sammich and a saline drip after, right Kev?!?!
Old 05-13-2017, 04:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #280 (permalink)
