Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
x2 on the Cerakote, great stuff, don't breathe it!!
I hope you had the manifold hot tanked in the stuff meant for alloy and not the one used for cast parts!
Is that a Squarewave 200? I have one also, great machine. I bought a gas lens for it, had a lot of TIG to do on aluminum docks.
Old 01-10-2018, 11:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #521 (permalink)
Turbo Powered Snow Blower
Jet washed.
I'm decent with the tig. Getting better. I needed a new mig and they had a two for mig and tig combo with a $1,600.00 rebate. So I upgraded my 30 year old 110mig.
Derrick
Old 01-10-2018, 01:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #522 (permalink)
Machine shop called and said the intake manifold is warped. Normal? Iím going to go look at it tomorrow and see how bad it is.
Sent from my iPhone while Driving
Derrick
Old 01-10-2018, 05:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #523 (permalink)
Ken911's Avatar
If it's not too bad you should be able to lap the ports to flatten them, it the warpage is between the two sides it will align when it's bolted down. remember it's an air cooled motor so things move around a lot.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
05 Cayenne S lapis blue
Old 01-10-2018, 06:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #524 (permalink)
Looked at the intake today. Twisted about .020. It probably would have tightened down flat. I just had them mill it flat.
I installed a time-sert in one of the stubborn studs. By the time I was done removing it the threads were too loose.
Cleaning up I found this on the floor near the engine. I looked at everything to see where it may have come from and canít find anything. I have rotated the engine several times and it could have fallen out?? I looked at the turbo feed fitting in the PET and didnít see it. That made the most sense to me.
Embarrassing, but Iíll deal with egg on my face before messing something up.
Derrick
Old 01-11-2018, 10:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #525 (permalink)
Alan L's Avatar
There is a ball about that size that sits in the hole under the idiot oil switch. That would make sense - Fell out when you rotated engine. No drama. Just fit it back in at re install.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 01-11-2018, 11:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #526 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Knee Pads are Overrated!
Rawknees'Turbo's Avatar
Not to be a nit-picking Richard about what Alan said, but the 9mm ball (like yours ) actually goes under the fitting that the idiot light sender screws into.
Its purpose is to help prevent oil from continuing to trickle through the oil supply line and into the turbo bearing cartridge after engine shutdown- potentially coking, etc. if it were to do so.
Old 01-11-2018, 11:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #527 (permalink)
79 #610 Winter Projects. Advise Needed
Thanks guys. Intuitively I thought thatís where it went to prevent drain back from the turbo feed line. But itís not shown in the PET.
Last thing I want to do is Assume.
Derrick
Old 01-12-2018, 05:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #528 (permalink)
Originally Posted by 1979-930 View Post
Thanks guys. Intuitively I thought that’s where it went to prevent drain back from the turbo feed line. But it’s not shown in the PET.
Interesting - it is not in the picture for your year, but is in the parts description (page 51). It is however in the pic for the 1987-1989 PET (page 46).
Old 01-12-2018, 10:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #529 (permalink)
^^^ That is not the first time I have seen a part my car has not shown in the diagram but shown in the later year diagram.
Derrick
Old 01-12-2018, 10:47 AM
  Pelican Parts Technical Article Directory    Reply With Quote #530 (permalink)
Alan L's Avatar
It is an aftermarket addition, that came on later cars.
TK sells a ball/spring kit - that works even better if there are still drain back issues.
Alan
Old 01-12-2018, 11:47 AM
  Pelican Parts Technical Article Directory    Reply With Quote #531 (permalink)
TurboKraft's Avatar
All Turbos 1978-92 have the 9mm ball bearing in the turbocharger oil feed block.
In the 1978-83 parts diagram, it is on illustration 110-10, final item listed -- but not on the drawing, and no reference number assigned, just a dash (-).
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 01-12-2018, 12:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #532 (permalink)
Should the 9mm ball bearing and spring kit be added to the 3.0L turbos?
Rahl
Old 01-12-2018, 12:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #533 (permalink)
Rahl, I just looked in the parts manual for the 3.0L Turbos and it shows the same thing as it did for Deez's - the ball is not pictured () but is listed in the parts description (the very last item on page 27).
Old 01-12-2018, 03:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #534 (permalink)
Thanks Ronnie! I thought it had one but the last time I had it apart was about 1991.
Rahl
Old 01-12-2018, 08:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #535 (permalink)
After drooling over Brianís 930 Targa engine and looking at the poorly painted fan housing and cracked cover on mine.
I stripped mine the rest of the way and plan on making another trip to the powder coater and zinc plater.
More work but it should look pretty when done.
Derrick
Old 01-15-2018, 08:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #536 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
