Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
And here you go ruining that sweet simplicity - shame on ye'!!!
Nice looking powdercoated parts, BTW (the CAR parts, not YOUR parts !).
Old 03-02-2017, 08:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
Turbo Powered Snow Blower
Well I have a feeling when I release an extra 100-150HP that is trapped by an outdated exhaust, turbo and intercooler. I'm going to need something better than a trombone to cooler her down.
Derrick
Old 03-02-2017, 10:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
You might need to wear a diaper for a while, too!!!
Old 03-02-2017, 10:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
"Ball Joints? Have you changed yours? At what miles were they needed?
Mine are fine. But I have this "while I'm in there" thought to replace them.
I guess I don't want to spend another $300 on parts and a tool unless It's needed."
80k on mine, they are ok. Unless you are into the boost all the time in Death Valley the trombone cooler should be ok, dirt simple and bullet proof, unless you are going to track it. How are you liking the lift?
Old 03-03-2017, 03:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Old car guy.....
Hot Euro's Avatar
After my first hard run in the west Texas 100* heat I found this 44 row oil cooler with fan at BAT, now she runs cool in any weather.
1981 SC Steel Widebody, DP Lid, 930/51 to 3.2l, K27 7006 Turbo, DOD, P&P Twin Plug heads, Twinfire Ignition, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, 044 pump, BLwur, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters
2003 BMW Z4 Daily Driver & Autocross car.
Old 03-03-2017, 05:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
Even the Carrera cooler with fan is barely good enough when caught in a traffic jam in temps approaching, or above 100 - the trombone would be crying for Mama daily around here.
Old 03-03-2017, 07:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
79 #610 Winter Projects. Advise Needed
I can't put into words how cool the lift is. I need under the car more. I walk over and push a button. I need the car lower or get in the car I push a lever. A very nice tool.
Derrick
Old 03-03-2017, 09:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
"Even the Carrera cooler with fan is barely good enough when caught in a traffic jam in temps approaching, or above 100 - the trombone would be crying for Mama daily around here. "
If you get caught in traffic jams I agree, all bets are off. Maybe the trombone would help in that situation if you get out of the car and blow on it.
Old 03-03-2017, 10:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Deez is a horn(y) blowing expert, so I bet that would work for him!
Old 03-03-2017, 10:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
I have the same cooler but without a fan,I wanted to put a fan on it but ran out of room.
Sent from my SM-N910T using Tapatalk
Old 03-03-2017, 01:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Old car guy.....
Hot Euro's Avatar
This 5" fan works great - I may have relocated my horns to make space.
Old 03-03-2017, 03:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
That looks really good,did you put the fan on a switch?
Old 03-03-2017, 03:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
That looks like the same fan I got.
I also got an adjustable thermostat controller that I am going to hook to the ground of the relay. It's just a probe type. But I figure I can adjust it to dial in the correct engine temperature.
Derrick
Old 03-03-2017, 05:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
If that can help.
Old 03-04-2017, 02:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
Old car guy.....
Hot Euro's Avatar
I put mine on a toggle switch in the console. I only have to use the fan on the hottest days.
Old 03-04-2017, 05:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
Thank you for the diagram.
It's good to hear that oil temps are not a major issue with these cars and the minor modifications I'm doing. We don't get the humidity here, but 100-110* is pretty normal June-Aug. I'll most likely be driving the F150 on those days, But who knows.
Derrick
Old 03-04-2017, 07:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
Question on the engine mods.
So I know I won't have time to get the exhaust, turbo, WUR, ect.. engine parts on for this summer. There would be the tuning issues that come with the changes and the countless "while I'm in here" things. Plus the stock clutch probably won't handle the increase in power.
So if I just do the headers and hook them to the KKK turbo were talking less than 50HP increase that should be easy to tune without a lot of drama. Yes / No???
Or are the turbo and exhaust bolts going to be frozen, break off and F-me into removing everything?
Derrick
Old 03-04-2017, 07:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
one of the great unwashed
patkeefe's Avatar
BTW, if you take your time and use lots of penetrating oil and maybe a little heat, you can get those bolts out fairly easily. It will still be a massive PITA, but they will come out. Removing fasteners is above all a state of mind.
Patrick E. Keefe
78 SC
01 Boxster
Old 03-04-2017, 07:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
Absolutely easy . . . may not even need to adjust control pressures with just that change, butt will know when you see what the AFR meter shows (butt you do currently have the choked like a chicken system on there, so might need adjustment when replaced). Regardless, easy to do with the Leask WUR.
Old 03-04-2017, 09:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
Will the modified WUR be needed for just the headers?
Derrick
Old 03-04-2017, 05:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
