SC cam p to v clearance
I've read a few times that there is no way piston to valve clearance will be an issue with SC cams and stock 930 7:1 pistons, correct? My heads were cut .008" and running 1.7 mm timing. Would just as soon skip the check and move on. Thanks.
Old 08-05-2016, 10:43 AM
never mind, did the quick check, no worries.
Old 08-06-2016, 09:15 AM
