Stock fender oil cooler: Which Fan
So which aftermarket fan are you guys using? I'm planning to put one in with a switch and relay.
Thanks.
91 535i
73 TR6
Old 10-01-2016, 12:48 PM
The elephant/patrick motorsport and other kits have a fan that is too large in diameter
Get new horns like the hella supertones that are little disks instead of the long trumpets
Get the later inner fender strut brace
fabricate a bracket for the new horns not the porsche bracket which is not available anyway right now
Get these from summit or similar
https://www.summitracing.com/parts/SPU-IX-30103013
https://www.summitracing.com/parts/der-16759
I don't like their wiring diagram though. Add a fuse where the main power comes off the batt. their diagram has a long unfused + wire.
Old 10-02-2016, 08:26 AM
I got one from either Summit Racing or Jegs, online, many years ago. It came with a thermostat, so once calibrated, correctly, you don't need to worry about a switch. Measure the width of the cooler and just order the one that fits. If you position it on the rear of the cooler, make sure you purchase one that sucks the air through the cooler.
I don't remember if I had to adjust the horns, or not. It's been too long ago.
Old 10-02-2016, 10:05 AM
Thanks. Gonna measure and order a Spal puller and a Derale adjustable thermostat (from Amazon). Curious, what fitting did you use for the thermostat probe?
91 535i
73 TR6
Old 10-02-2016, 10:39 AM
I only remember that it had a two or three inch long thin probe that slid in the cooler's fins. I placed it next to a vein where oil was flowing. I don't remember how I secured it...Maybe I didn't. The kit that I purchased had its own inline fuse/relay, too.
Old 10-02-2016, 12:11 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Originally Posted by icemann427 View Post
I only remember that it had a two or three inch long thin probe that slid in . . .
Old 10-02-2016, 01:38 PM
Talking
Originally Posted by Rawknees'Turbo View Post
I call it "My Lil' Rawknees"...
Old 10-02-2016, 01:45 PM
Bam - now that was a goodun', Icyhottness - perfect!
Old 10-02-2016, 01:49 PM
