Conversion to Precision 5862 Turbo
Title say`s conversion to a new Turbo after experiences with K27/7200; K27/29; K27 Based Turbo from ETG (never run correctly).
Numbers from the new Turbo: - PT5862 - 58mm inducer compressor wheel (Billet) - "Ported S" compressor cover 4.0" inlet/2.5" outlet - 62mm, 76 trim turbine wheel (A/R 0.82) T3 (T31) 4-Bolt - air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA) Some Picture: http://forums.pelicanparts.com/uploa...1471166075.jpg http://forums.pelicanparts.com/uploa...1471166100.jpg http://forums.pelicanparts.com/uploa...1471166119.jpg http://forums.pelicanparts.com/uploa...1471166141.jpg http://forums.pelicanparts.com/uploa...1471166158.jpg |
Fitting Test
Before I bought the new Turbo was clear to me that I have to make some modification.
- Oil feed restrictor - compressor inlet / outlet modification - T3 / T31 muffler fitting issues Fitting Test: http://forums.pelicanparts.com/uploa...1471167243.jpg http://forums.pelicanparts.com/uploa...1471167258.jpg http://forums.pelicanparts.com/uploa...1471167271.jpg http://forums.pelicanparts.com/uploa...1471167296.jpg http://forums.pelicanparts.com/uploa...1471167311.jpg |
Fit on T3 Flange
Some work with the carbide milling cutter:
http://forums.pelicanparts.com/uploa...1471188758.jpg http://forums.pelicanparts.com/uploa...1471188773.jpg http://forums.pelicanparts.com/uploa...1471188787.jpg |
Muffler Flange Modification
Don`t fit:
http://forums.pelicanparts.com/uploa...1471188912.jpg Need some modification on the muffler flange: http://forums.pelicanparts.com/uploa...1471189039.jpg |
I bet you'll love that thing! The hp numbers I've seen from these are huge. Can't wait to hear the results!
I'm sort of surprised PTE doesn't make some kind of direct fit replacement or close for the Triple K 3LDZ 930 application. Market is probably way too small now, though.
930 is a tiny, tiny market, then you have those trying to keep originality plus those who feel nothing holds up as long as a triple-K. There's only losses to sell to the 930 market. |
That turbo does look freekin bad to the bone,looking forward to hearing the difference between this one and the one you just took off.
Sent from my SM-N910T using Tapatalk |
Tada! Keep on working Thomas, hope to see some info about performance soon.
Missed an earlier pic. I'd get the proper 4" to whatever size that black inlet pipe is in silicone adapter.
Your anti-surge ports might do something funky???? Don't think you can leave those ports open like that??? |
Yes looks like a custom inlet pipe is next.
What do you anticipate the characteristics of this turbo will be on your engine with the mods you have in place? I notice it is not split plenum, do they offer that option? |
have a straight hose connector (before cutting) http://forums.pelicanparts.com/uploa...1471289251.jpg |
Turbine outlet size 2mm bigger as a K27/7200 and Compressor inlet size is 3mm smaller as my K27/29 with the 61mm Holset. Hope i love the duall ceramic ball bearing too. |
| All times are GMT -8. The time now is 02:09 PM. |
