Exhaust Coatings
Whats the choice of coating for your exhaust? I have tried a dozen types of spray cans all of them have failed, try the exhaust wrap, also failed, is there anything out there better that Jet Hot Coating?
10.76@139-1/4 mile 0-1 mile 193MPH I Love to Shine Cars
Brando
Like jet hot there are products from techline coatings. They're ceramic and come in many colors. They're nice. Cermachrome is the popular choice but there is a white, blue, black etc. nice stuff. Keeps heat down.
Turbo powa! 1977 911s. it's cool |
Anything on these cars must be able to withstand 2,000F.
Caution though that may coatings are nothing more than high temp powdercoat and offer no thermal barrier properties, they just look good. Jet Hot is one whose product really does reduce radiant heat.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
How is the Zircotec different from the others?
Ceramic Coating for Supercharged / Turbo Applications
If it's a turbo application, traditional Jet-Hot / polished ceramic coating will not survive very long. Polished / bright ceramic coatings are only rated at 1000F - 1100F metal temps which translates to about 1200F - 1500F EGT's. Additionally, short tube headers and exhaust manifolds won't hold up well either even in a normally aspirated application. For any applications noted above you'll need a "High Temp" Ceramic Coating which is rated at 2000F+. These coatings can endure the abuse of any turbo application..... |
CCPCoatings.com,
Thanks for the info, I will let a professional do them this time, my concerns are as you mentioned with the Jet-Hot / polished ceramic coating will not survive very long, that's stuff is hot down there big time.
Hello juan ruiz,
I looked during some time(long enough) before holding(retaining) the treatment(processing) Zircotec, he(it) appeared to me the most serious in this domain. He(it) ya several colors but the white is the most effective, I preferred the efficiency to the appearance. A small search(research) on the Internet will give you all the information which you would wish, it is an English company.
I have the same coating on my headers, holds up well but under high boost it will blister or melt off in the areas that normally glow red.
Yes
You would have normally been able to run their guarantee of one year, me for the moment I have not started my engine yet, I hope that that will be resistant and especially effective for the heat. Would you have a photo of your exhaust Zircotec? Is it some white ceramic?
Brando
That is sexy!
My oil drips would destroy that look in no time.
So it goes without saying, if anyone is running this type of coating, you MUST inspect your exhaust system periodically for any signs of fluid saturation. This should be fairly easy at first when the pipes are bright white. Perhaps a bit more difficult when the pipes become dirty with road debris / use. |
I've used Jet hot extensively but recently giving Polydyn a try.
Jet hot are quite expensive now compared to their pricing from a few years ago. Polydyn are 1/2 the price with the same warranty, they don't have the same range of colors as Jet Hot but still offer 3-4 decent colors in their Turbo application. I can post pictures if you're interested. Yasin
Ole Skool - wouldn't have it any other way |
Brando
Tech Line Coatings | Automotive ( Hi-Performance ) Coatings
Excess of 2000* surface temps.
![]() This is going to turn into another out of body experience, first to find the right stuff, then to find it locally.
Jet Hot on Rarly L8 Headers: ![]() I'll post some pics of the Polydyn coated header tomorrow. Wow..good to know, I had no idea they went bankrupt a few years ago.
