The oil ? Has been beaten to death. You'll find for every kind of oil there are 100 conflicting opinions. Lots of threads on the oil topic. Personally I think BP is Way over rated and WAY over priced. Good luck.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 09-03-2016, 12:43 PM
I have the new cam hose in hand. Do I need new banjo washers or other? I haven't sourced them yet.
About the oil, I'm going with Valvoline VR1 20W-50. Was able to pick it up locally and quite reasonably priced at $4.88/qt.
Find Spoke's LED Products:
www.spokeworksled.com
Old 09-15-2016, 05:03 AM
T77911S's Avatar
yes you need washers.
get extras and also get the one that goes under the adapter that the banjo bolts to...just in case
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 09-15-2016, 05:22 AM
Are the washers something I can source locally? I didn't order any from Pelican.
Old 09-15-2016, 05:34 AM
Replacing the cam hose now. I want to remove the distributor but the control wire is still connected. There is a screw holding the plastic piece in place.
Is this a connector?
It looks like the other end of the wire goes straight into the wire harness and doesn't have a connector on the other end.
Old 09-17-2016, 08:33 AM
The new piece look similar to the existing piece but not the same.
The tap-off port is located further up the pipe and the bend in the compression fitting end is facing the wrong way.
What is up with this? Is the the wrong part or just different?
Old 09-17-2016, 09:25 AM
OK, the compression end of the new pipe is ok.
Turns out the connection to both sides of the existing hose are loose enough to spin easily by hand. Hmmm.....
Next question, since the existing hose had a pronounced "S" bend in it, is it possible to bend the new pipe (using a pipe bending tool) to minimize the hose bend?
Old 09-17-2016, 09:37 AM
I found the banjo washers on Pelican but can't find the compression fittings needed on the end of the pipe. Where can I find this part?
Old 09-17-2016, 03:11 PM
Here's the compression fitting...
Old 09-17-2016, 03:21 PM
BoxsterGT's Avatar
Porsche Crest
Just came across this thread.....
I have these Cut Rings & Nuts in stock. Please email me for info.
Len at Autosportenginering dot com
Old 01-23-2017, 03:52 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
