I removed the shifter and removed the JB weld and then brazed the short shift rod on with brass rod. Then I heated up the steel shift rod where it bends back red hot with an acetylene and oxygen torch and bent it back a little farther and a little to the left so the shift knob was a little more to the left but didn't hit the right front corner of the driver seat when in second gear. I put an old wet towel on the driver seat first so it wouldn't catch on fire. It worked well and I like it much better now. After all that the leather boot covers the burned up paint area on the shift rod or you can remove it again, sand it smooth with 320 or 400 grit, and spray it satin black so it looks nice. |
Brando
OMG! Your gears are tall.
Turbo powa! 1977 911s. it's cool |
Sorry, Thanks Tippy. Want to talk to a friend of mine who runs a stroker Grand National. I think he pulls timing in first and second. I can't do it gear by gear though. This gear box was set up to run the standing mile. Still works good on the street, like a 3 speed. 2.25 1st,1.25 second, .76 third, .51 fourth.
Pulling timing has not worked. Next option is race tire or programmable boost controller. Any one using a programmable controller?
Turbofrog
dont you have efi? if there is no boost for gears or speed then you need to get a controller that has its own speed sensor.
************************************************** ******************************* 79 930: HX40Super, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, BB+2*turbosmart38, WMI. Weight 1110kg |
Mine is a manual knob right now. I really want to keep the power in the car and work on getting it to the ground.
Slantnose from HELL
Where is your AFR's before boost onset?
It changes from time to time..... |
Slantnose from HELL
I would fatten it up a tad. Typically less timing will boost faster but make less power. A little less timing and lean not so much. Leave the timing alone and give her just a hair more fuel before boost onset.
Thanks, I tried that. With the longer gears, the faster it spools the quicker the wheel speed and the more traction loss. Trying to take another route now with either variable boost per gear or really sticky tire. Loosing traction at 20 lbs boost now, so turning it up to 22- 24 lbs will be impossible if I can't get it to hook. Going to add more wing at higher speed to see if more down force helps also.
Second for the Wevo w/tall shift knob. He was developing a "tall boy" shifter, not sure of the status, but may be worth a call.
Harold '79 930/DP935 '68 VW 3.3 Turbo Crewcab |
Turbofrog
I think for drivebility you need to control boost before stickies. has anyone installed speedsensors on front hub?
Anyone using the turbosmart electronic controller?
Slantnose from HELL
Understood,
Greedy use to be the controller of choice. But ever since boost control was added to just about all EFI systems it put a hurting on their parade.
Sent a message to one company. I think I found one where boost can be changed with a switch with 6 settings. Can hook the switch to shifter or clutch pedal and change up as conditions permit and use lower setting in poor conditions.
Thread Tools | |
Rate This Thread | |
