 if you have any kind of miles on the car you should see wear grooves in the bolts from the pin, at least I did.
	when I did my test it did not suck a lot but it should empty the jar.  |
 There should be some wear marks where the drive pin is contacting with the bolt heads - even slight marks after very short use. Or if still in doubt, some engine blue on the pins should show you where they are contacting. I would still be surprised if they weren't contacting, but ... if it works fine now....
	Alan  |
 Johan  |
| All times are GMT -8. The time now is 05:08 PM. |
