Originally Posted by JK930 View Post
UPDATE:
We tried a brand new Bosch coil car started right up and smooth
ran for 6 minutes and then died.
You need to hook up an AFR meter... It will tell you what happens right before the car dies...
Old 10-13-2016, 09:37 AM
Originally Posted by T77911S View Post
I am interested in the this spark tester that he used.
spark plug tester looked like this
6 12V in Line Spark Plug Pick Up Coil Tester Engine Ignition Diagnostic Tool | eBay
Old 10-13-2016, 09:46 AM
oh, your problem. the coil can heat up and cause it to stop running, I would look into the mixture and fuel pressures.
that seems pretty fast for a coil to heat up and quit.
he had the gauges on the car when testing/ monitoring the WUR
Old 10-13-2016, 09:47 AM
Alan L's Avatar
You would have to start thinking of the CDI box.
There is a test procedure listed somewhere - checking values across the pins.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 10-13-2016, 10:57 AM
Alan
he took a alternate good cdi box (one of his spares)and put it in my car to rule out the cdi
same scenario 2 different cdi's
Old 10-13-2016, 11:23 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
