-   -   strange noise (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/931276-strange-noise.html)
MaRu 10-06-2016 07:20 AM
strange noise
Hello,
does anybody has an idea what this noise might be?
https://youtu.be/0VqzSzGa8Ws
You can her it clearly in the Video and it comes from where I put my fingers on.
many thanks in advance,
Malte
Rich76_911s 10-06-2016 07:45 AM
Your video is set to private so I was unable to see or hear it.
MaRu 10-06-2016 08:02 AM
Oh sorry! It should work now.
Beth641 10-06-2016 08:13 AM
problem in ignition.. or electric supply is not proper
mark houghton 10-06-2016 07:21 PM
you're pointing to your boost recirculation valve housing, if that's the clunky noise you're referring to. Never heard of a recirc valve clunking at idle, though somewhat common when goosing the throttle at idle if the gaskets at the end caps are worn and the internal piston contacts metal instead of the gaskets.
MaRu 10-07-2016 01:03 AM
Thank you guys. What I did to make this noise better to here is that I turned the dizzy 5 degrees to the left and right while filming. This i sthe reason for the up and down of rpmīs. Everytime the rpms change the noise apears. I will check the gaskets!
MaRu 10-07-2016 08:25 AM
I just found out that here is no vacuum at the wastegate
Rawknees'Turbo 10-07-2016 10:07 AM
The wastegate doesn't have a vacuum connection - the port on its side is for boost pressure (hose that runs from intercooler) and the port on the top is a vent to atmosphere (the hose is not connected to anything in the engine bay).
MaRu 10-07-2016 11:11 AM
Thanks, I have an original Porsche workshop manual and it says at idel there is a vaccum which turns into boost pressure with rising rpm.
