Turbofrog
Just put my 930 to sleep
Well for the winter anyway so no worries about totaling it if the title got you worried.
Too many things on my mind and on todo list but hopefully E85 conversion and rs interior. Hopefully some rim/tire work and some paint work too. If I have time maybe even suspension swap for bigger torsion bars and raised spidle shocks I've had in box for 5 yrs. Oh, and small lithium battery and eberspacher air heater for cabin. Sunroof fix definately and bendpak 5000slx for easier ergonomics. My fueling got lean ( after 5000rpms) after I swapped my front pump back to stock or just because the air is so much colder right now. I think I got almost all out of the CIS with 7.9 sec 60-130 so if I get the E85 conversion done I hope to get about the same kind of performance out of it. The boost was pretty high at 1.3 bar and I'm not going to raise it so not going for more power but safer and cheaper power.
************************************************** ******************************* 79 930: HX40Super, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, BB+2*turbosmart38, WMI. Weight 1110kg |
Turbo Powered Snow Blower
It was 88* and a great day for a drive in NorCal today.
Almost put my 930 to sleep for good when a 6 point buck hopped across the road from behind a bluff at 8am on the way to a cars and coffee. 4 wheel smoke show sliding at him as he took his second hop 5' off the front bumper and across the other side... Closest I have ever been to a live buck.
Derrick |
Turbofrog
These brakes without ABS are not that good when you need to react! Its fine on track where you know you need to gently start braking not to lock the fronts and then when you get some weight on the fronts go all the way. Atleast thats how mine is right now with stock torsion bars. Very easy to lock the front wheels.
I did 3k miles this summer so more than the previous years and no problems before this cold weather lean thingy.
************************************************** ******************************* 79 930: HX40Super, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, BB+2*turbosmart38, WMI. Weight 1110kg Last edited by smurfbus; 10-09-2016 at 08:41 PM.. |
Agree. I usually have good control with standard brakes. This is the first time in as far as I can remember hitting the panic button partially. I was in control sliding, I knew I was not going to hit him, I just held it straight and watched the show in slow motion.
Derrick |
Mighty Meatlocker Turbo
DeezNutzDerrick failed to mention that he didn't initially see the deer in front of him as he was looking at neekid hotties on his cell phone screen at the time!!!
Only hard up Texans use their phone for that. I have a real life hottie that took care of that distraction last night...
Derrick |
Ouch. Nor his, I'm guessing.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Thread Tools | |
Rate This Thread | |
