Scottsdale Arizona USA
Bore manifold and order the TK EFI tapered bore blocks!
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design +1 (844) URO-PART // mode@europartswest.com |
Tapered bore, that sounds fun! You guys are a bad influence
![]() Rawknees yes, I need to find a better tranny, one that's bigger, stronger and can take a real beating. ![]()
Cheers, Chris 1986 951 SOLD: ![]() |
Hey fellas, since 400+ whp from an EFI swap will absolutely destroy my 915, I'm thinking I could dail back the boost from my current .9 bar to .8 or .7 and still have a power increase and the reliablility of EFI. What do you think? Then maybe I won't kill my trans so fast?
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
^^^ Yes I hear you but I'd like to wait a little bit before spending $10k plus on a tranny swap.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante '01 996tt Ducati 748R |
TK EFI 36mm / GT30 / Wavetrac diff / Billet side cover, w larger bearing / Internal bearing plate if coming apart / transaxle cooler system / 1986.5- output flanges / driveshafts (larger g50 type). All should be smooth and efficient with that setup.
Thread Tools | |
Rate This Thread | |
