LinkBack | Thread Tools | Rate Thread |
Turbofrog
Any chance I can use stock oil temp/oil pressure sensor for ms3 input?
I can find linear sensors for about 27usd shipped so its not that bad but stock would look kind of well stock.
How about logging or input stock oil pressure for limp mode/kill switch?
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg Last edited by smurfbus; 11-02-2016 at 10:44 AM.. |
I don't believe you can use the stock one.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
Turbofrog
Some people on the tehcnical forum have tried to measure the output but the results vary ALOT. There are some VDO specs though like
For oilpressure I found these measurements for 911 sensor (930 could be totally different) Quote:
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
930T Owner
Wouldn't be hard to plumb a t fitting up there so you could install whatever sensor you want.
Scaling the oem sensor would be the easier path.
Hams930T 2017 Turbo S |
Chain fence eating turbo
Yep, just use a DMM and put the sensor in different Temps of water and measure output.
Only need 2 points of data. |
