935 Boost gauge hardware booster line
Can anyone tell me what brake booster check valve needs to be used for a 935 style boost gauge that fits in the clock hole? I pulled my stock Ate check valve and it has one nipple, what vehicle application should I look for the part that has the check valve with 2 nipples - one to feed the booster and then one smaller nipple to feed the boost gauge?
I see North Hollywood Speedometer has one in their kits - anyone know what application that part is from?
VintageExcellence.com
Old 11-17-2016, 03:58 PM
xbmwguy's Avatar
Install a "t" in the reference hose,clamp it,and call it a day
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp
Old 11-17-2016, 04:10 PM
Hmmm here is something interesting from a 924/944. Anyone herd of this being used before?
1985 Porsche 944 Base Coupe - Brake Hydraulics - Page 4
Old 11-17-2016, 04:26 PM
Old 11-17-2016, 04:27 PM
You could call NHS and nicely tell them you had one and it exploded and almost blew your hood off.
They might say, How terribly sad for you both.
Or they might make you a deal on a new on.
Old 11-17-2016, 05:21 PM
Crotchety Old Bastard
RarlyL8's Avatar
... or you could run a line to the engine and not cut into your BRAKE SYSTEM.
Old 11-17-2016, 05:46 PM
TurboKraft's Avatar
Originally Posted by confused View Post
That's the one.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 11-21-2016, 08:37 AM
Thanks Chris, that what I was looking for.
Sure it taps into the power assist to borrow a signal, not the actual brake lines. If Porsche supplied the gauge new on the car then I would bet they would use the same method. It's not a major infringement on the brake vac system.
Old 11-21-2016, 08:57 AM
TurboKraft's Avatar
Yes, and just as effective as running a whole new line to the engine
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 11-21-2016, 09:33 AM
I am a bit in the same situation.
Only difference is that there is no brake booster on a 76'
Is there somebody who maybe has a time correct solution for a connection to the airtube?
I wonder also,there is a airline near the paddlebox might this be made for this?
It exits at the end,its the small pipe on the left.
Old 11-26-2016, 11:37 AM
You could run a stainless braided 8mm fuel line through the tunnel or along the floor where it's out of the way and use it for the boost gauge. The braiding is for abrasion resistance.
Old 11-26-2016, 08:13 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
