T77911S's Avatar
fuel injector lines needed
my number4 injector line has a slow leak at the fuel head. I cant get it to stop/don't trust it.
I found a new one for $45
was thinking of just replacing all 6 if the price is right or if someone has #4 they want to sell I could use one.
also would not mind a new set so I could use mine to do injector testing.
its the large diameter euro lines.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 11-21-2016, 04:53 AM
TurboKraft's Avatar
Tried the dealership? They used to be <$300/set, but for a while one of the lines was NLA.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 11-21-2016, 09:08 AM
T77911S's Avatar
i was hoping you would pop in.
figured with all the EFI you put on you should have a good set or at least #4 laying around,
ECS claims they have #4 for $45, which would be just under 300 for a set. hoping I could get a good used set for 100-125 since they are all being removed and not really in demand.
I would like a set just so I could bend mine so I can do FD/injector flow testing since they are not perfectly straight anymore. they look OK they just don't go into the injectors/fuel head straight on and it makes it hard to keep them from leaking.
Old 11-21-2016, 10:26 AM
T77911S's Avatar
any chance you have a set of SC cams for a 930
Old 11-21-2016, 10:34 AM
I have a really nice pair of SC cams i'll let go pretty cheap. They'd need the scavange pump mod done. John D. does it for around $125 iirc
Shoot me a pm if you're interested.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 11-21-2016, 11:00 AM
TurboKraft's Avatar
No dice, sold out. They are still in demand because guys modifying their cars but staying CIS still want the Euro parts.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 11-21-2016, 11:44 AM
Concerning the fuel leak there is an alternative to new lines if you choose.Conical Seals.Secoseals or Flaretite.I use a few and problem solved.Usually stocked at your local Hyd. outlet.I have the Euro lines also.Cant say for sure but I think they were #4 in size,
Old 11-21-2016, 04:11 PM
fuel lines
I have these lines. Not sure if this is what your looking for? Let me know. Philip
930 parts
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 11-22-2016, 03:49 AM
T77911S's Avatar
that's the skinny ones.
are those things in the plumbing section? what would I ask for.
I have considered Loctite or curilT if that would help.
I got the one at the FD to stop, but now the other end is a very very small leak. if those things don't in at the correct angle it leaks and when I slightly bent them to do a flow test that was enough to make life miserable. live and learn...$$$
Old 11-22-2016, 05:08 AM
