Scavenge pump
Today I had a chat with a rebuilder of turbos and he was well versed with my K27 7006. From what he discussed with me suggests that unless the bearing has let go it was unlikely that the turbo is the problem. He suggested the issue could be more to do with the scavenge pump.
Question is can I test if it works once I remove it as now the exhaust,catch return can, turbo and intercooler have been removed. Secondly can a scavenge pump be rebuilt as I read that they are no longer in production. Thanks sbk930. ![]() ![]() |
Turbofrog
You test it when engine is running with external bottle/canister to see the level, so not really possible to test otherwise. There are sealing kits for the pump and if the dovelpin has gone bad you can use some other similar size parts. There are threads for testing/rebuilding here if you search.
************************************************** ******************************* 79 930: HX40Super, MS3pro+ID1000+044+E85, Ignition: 123/TUNE/MSD6A, BB+2*turbosmart38, WMI. Weight 1110kg |
If the test fails, Clewett has a very good aftermarked scavenge pump
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Turbofrog
But spendy. I also thought about purchasing it as it has cam timing setup for EFI.
its easy to rebuild. not a bad idea is it leaks oil\
don't forget the crush washers
86 930 42kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 05 BMW 330CI 130K:: [_ ![]() 08 VOLVO V70 190K:: [_ ![]() 90 B2200[__] RUNNING:[ ![]() ![]() |
there are seals on the shaft that keep oil from leaking out. they look like little piston rings, there are 2 on each end. they can and will leak oil.
if you have your muffler off check the shaft for play. if oil is coming out, have it rebuilt.
Just re-sealed mine. It's a piece of cake. TurboKraft sells the seal kit for it.
'79 930 turbo RoW - Oak Green Metallic - k27-7200 - Kokeln Intercooler - RarlyL8 headers/muffler - Leask WuR - Tial 46mm - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 '99 4Runner Sr5 |
Thread Tools | |
Rate This Thread | |
