LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Cylindeer Head Temp Sensor
Hi All
I am currently using a Bosch CHT sensor. It's fitted in the head of cylinder number 3.
Warms up very quickly. I would like to retain this, but I don't want to have to take apart the shroud in order to test the temperature calibration.
Anyone have any data on this sensor?
John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 57lbs. Cobra Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 12-04-2016, 05:36 PM
Old 12-04-2016, 05:38 PM
Originally Posted by jpilcher View Post
Hi All
John
Hi John, I have my sensor installed on cylinder #1, and just have to pull off the cover plate at the end of the shroud to get to the sensor. About 10 min work to get at it. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 12-05-2016, 02:22 AM
Now that I think about it, I should be able to check temperature and ohms as the car warms up using my current setup.
Old 12-05-2016, 08:27 AM
TurboKraft's Avatar
If you don't want to have to build your own sensor and prefer a bolt-on solution for engine temperature:
This is a simple kit to install. The heads warm up more quickly than the 10+ liters of oil, and more accurately reflects the engine's temperature for a warm-up cycle.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 12-05-2016, 09:31 AM
Hey Dos531(Derek)
Sent you a PM regarding tracking number.
John
Old 12-06-2016, 06:06 PM
I like that TK set up, how does it attach to the head? Drill and tap a hole in a fin?
Old 12-06-2016, 07:16 PM
Looks like something new is on the way.
1987 GP White 930
1977 Ford Bronco
Old 12-07-2016, 04:18 PM
Any info on this? Web link?
Old 12-07-2016, 06:01 PM
TurboKraft's Avatar
Sensor's plate insert between the fins, protrudes through small slit in #3 sheetmetal, sensor's mounting block attaches to plate. Super simple, more than accurate enough to serve as a reliable engine temp sensor.
Compared to using oil temp -- the engine warms up sooner, so gets out of cold start mode sooner, drives better sooner.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 12-07-2016, 08:45 PM
TurboKraft's Avatar
Why do ECU manufacturers insist on mounting connectors atop the ECU? No more mounting it under the seat like factory -- if someone lowers the seat and adjusts it fore-aft, it hits the ECU connector.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 12-07-2016, 08:48 PM
Not really. DIY Auto Tune posted it as the banner image on their Facebook page. The Performance Racing Industry trade show is this week in Indianapolis so maybe they will announce something there.
1987 GP White 930
1977 Ford Bronco
Old 12-08-2016, 04:54 AM
Chain fence eating turbo
Exactly! AEM and MS3Pro both do this.
Haltech Elite has it right!!!
Old 12-08-2016, 05:33 AM
I have my ms3 pro under the seat and there is plenty of room between it and the bottom of the seat.
The one thing I really don't like about the connectors being on top of the ecu is the danger of something falling inside the connector socket and wreaking some sort of havoc.
Old 12-08-2016, 05:38 AM
How difficult is it to install with the engine in the car?
Old 12-08-2016, 08:17 AM
TurboKraft's Avatar
Easy
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 12-09-2016, 08:19 AM
I would rather be driving
jpnovak's Avatar
I can't stand top mounted connectors either. Ok for a race car where you need access. Not great for a street car where you mount discrete. No options for 90 deg connector either. Same problem from many vendors.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 12-09-2016, 12:07 PM
John, do you have a tuner locally that can help you with this once your done? Philip
Old 12-10-2016, 11:06 AM
Hey Philip
Yes, There is a dyno shop in Burlington that tunes Megasquirts, 20 minutes from my place.
I should be able to get off boost map dialed in. Boost really needs a dyno. Especially on ignition side. Hoping to get some help from Pelican brain trust.
Old 12-10-2016, 11:46 AM
Hey Philip
Your lucky to have someone so close, it's a 4 hour drive at least for me, to the closest Porsche tuner/dyno. ;(
Old 12-12-2016, 03:39 PM
