Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Well I finally received my pulley from GSF.
I was getting worried because Alberts email was coming back Un-reachable. His webpage is down as well.
Anyway hope to get started this week, on removal of SDS.
Question regarding signal wheel. I have a
36-1, should gap line up with Z1?
Old 05-29-2017, 12:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #161 (permalink)
Looks like a nice wheel! Is that all the parts your waiting on? Can't wait to see how it turns out. ;-)
87 930 GHL/Rarlyl8 dual/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LC-1/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin plug coil packs/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo install in progress. 500+ HP, BTSOMP Dyno
Old 05-29-2017, 01:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #162 (permalink)
scottrx7tt's Avatar
albert must have switched suppliers, because mine does not have those open areas.
1979 911SC widebody conversion. 3.1 engine, 3.2 liter heads, carrera intake, Microsquirt V3 ECU, K27 7200 High flow turbo, Tial F41 wastegate, Ford EDIS. .7 bar. 402hp 360tq
Old 05-29-2017, 02:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #163 (permalink)
Hey Phillip
Yes, that was the last piece. The crank pulley appears to be a quality piece. Yes cutouts are a new design. Seems fairly light. Pulley also has index marks at 60, 120, & 240.
Tomorrow night I plan on running ground wires from battery to rear engine compartment.
I will make sure I take lot's of pictures.
Cheers.
John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 57lbs. Cobra Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 05-29-2017, 03:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #164 (permalink)
John, take lots of pictures! I like all the options MS3 Pro has. A lot more than our SDS, although SDS was a good learning curve. I might be tempted if yours turns out good...
Old 05-29-2017, 05:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #165 (permalink)
Hey Phillip
I think it comes down to planning, as to whether or not it is successful. I am taking my time this conversion. I have my E test out of the way, so I don't have to worry about dialing the tune in on the street. There are a few things I want to pretty up while I'm in there Valve Covers, Intake Manifold, Intercooler. I also want to tidy up the wiring.
I'm trying to decide on what device to use for tuning. Laptop, Raspebeery PI, or a tablet.
I think your car would really benefit from the MS3 Pro. Electronic Boost control, Meth Injection control, Launch control, etc. The thing I didn't like about SDS is the idle quality, I am hoping for great idle characteristics from MS3 Pro. I do realize that it all comes down to the tuning. I have gotten my feet wet with the SDS system. I am hoping the sequential will make a big difference.
Cheers.
John
Old 05-30-2017, 08:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #166 (permalink)
Hi guys
Picked up some 5mm hex bolts for reference wheel. What torque should I tighten them to?
Should I use medium thread locker?
Old 05-30-2017, 03:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #167 (permalink)
Old 05-30-2017, 03:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #168 (permalink)
dos531's Avatar
Hi guys
Yeah I did hex bolts on mine as well and used blue loctite. Location of the gap doesnt matter either, as it's set in the software. Makes it easier to know where it is for ease of setup though.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'01 996tt
Ducati 748R
Old 05-30-2017, 03:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #169 (permalink)
Thanks Derek.
Old 05-30-2017, 04:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #170 (permalink)
Blue lock tite on 4 5mm bolts, torqued to 5 ft-lbs.
Old 06-01-2017, 05:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #171 (permalink)
Well a little more progress today. I got started on removing SDS EFI system. Started up front at battery, disconnected negative ground.
Old 06-04-2017, 02:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #172 (permalink)
Then I moved back to SDS ecu. The SDS Ecu is mounted on left rear footwell.
I removed the left side panel to can access to SDS wiring harness that goes to the engine compartment. I removed the mounting plate from the foot board and the SDS ecu. I disconnected all the wiring harnesses that go to the SDS Ecu.
Old 06-04-2017, 04:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #173 (permalink)
Here is SDS Ecu, programmer, and Tuning Knob.
Old 06-04-2017, 04:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #174 (permalink)
Then I moved onto the engine bay. I removed the inter cooler, air intake tube, spark plug wires, then snaked the SDS wiring harness from the interior to the engine compartment.
The coils and mounting plate was the last thing to be removed. I still have to remove the VR sensor, and crank pulley.
Old 06-04-2017, 04:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #175 (permalink)
Made a little more progress today. Got the MS3 Pro Ecu secured to mounting plate.
This will be mounted on left rear seat foot board.
Old 06-06-2017, 04:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #176 (permalink)
I plan on reworking rear relay and fuse panel.
I am adding a 10 fuse panel, controlled by a 40 amp relay. The relay will provide switched power to the fuse panel. The power will be supplied from the original harness pin 40. The fuse panel will supply power to coils, injectors, Boost controller, cam sensor, etc.
I will also be providing a ground terminal block
that will connect directly to the battery. I will use this to ground all the MS3 grounds, etc.
I will also be providing a terminal block for the sensor returns. This goes back to MS3.
I was also thinking of mounting the Electronic Boost Controllor.
Old 06-06-2017, 05:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #177 (permalink)
Where is best place to mount Electronic Boost Controllor? I am running a multi port vacuum block.
Old 06-06-2017, 05:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #178 (permalink)
Why don't you build a bracket and mount the EBC where you had your coil packs located ? Nice open area , and easy to run your vacuum/boost lines.
Old 06-07-2017, 02:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #179 (permalink)
Good idea Phillip.
John
Old 06-07-2017, 04:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #180 (permalink)
